School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
The Yaris sucks.
Blew the serpentine belt with a hair under 39k miles.
Left me stranded and delayed my trip home by five hours, plus a bill for a new belt and 3/4's hour labour - on a Sunday. At least Toyota gave me a one-time-only courtesy tow (just past warranty). ![]() Whichever engineer decided that the Yaris should not have an automatic tension adjustment should be shot, plain and simple. Re-tightening the belt every oil change, with a new belt every 30k miles (per my dealership's service manager) should not be SOP. That's just ungodly stupid. /End rant. |
My original belt lasted me 90,000 miles. You shouldn't have to re-tighten it at every oil change.
Mr. 155 and climbing
I have 63k on mine and my belts all look to be in great shape...this thread made me check since it has been a while...not sure why yours crapped out so soon? Perhaps environment?
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
Yeah, I see why the Yaris sucks. Most cars' belts fail on workdays- your Yaris was just downright inconsiderate.
Finding a suitable shop on a Sunday is a PITA. Obviously the car did not "choose" the day, but bad luck sure seems to find me...
fnkngrv: Mine did as well, I just checked it not 2k miles (at my last oil change). The problem is once the elasticity "gives" a bit (in a permanent way), your belt gets loose. However, you'd be almost hard-pressed to tell the difference from a snug belt and a loose (and soon-to-fail) one. Most cars have automatic adjusters that "spring out", for lack of a better word, keeping it taught and tight. However, the Yaris has a single adjustment point on the alternator bracket, which needs to be manually adjusted with a long - 3-4 foot - breaker bar, to keep the belt super-tight, and a single bolt that's almost impossible to break free without stripping threads. As you can guess, I do not travel with a three-foot breaker bar in my hatch.
I thought there was 2 bolts. 1 bolt to loosen from the bracket, and the other front bolt to adjust tightness. I know the breaker bar method cuz I used it on the crx alot.. but I dont remember bringing out the breaker bar when i did my pulley swap.
Per the service manual, the belt should only be retensioned once after it is run for a short time after initial installation. Chances are your water pump will go soon as well from your service people constantly overtightening the belt.
#8 | |
Drives: yaris Join Date: Jan 2011
MOST engines never have a floating tensioner on the accessory belt. only the timing belts have floating tensioners. accessory belts need to have occasional static tension checks with a tensiometer, adjusted accordingly, then locked in place |
#9 | |
MOST V6 V8 motors use floating tensioners on serpentine belts. I usually see them on the RWD motors where the belts is in the front of the car. usually FWD have the adjustable ones. At least this is what I have noticed as a Toyota/Lexus Tech..
#10 | |
non auto-tensioned belts also dominate the market. it is proven technology. you need to check it's tension and condition when the oil is changed. |
Im just saying, someone who works on more luxury cars (lexus, infinity) tend to see more floating tensioners than adjustable ones.. Not saying your statement isn't true, just saying your statistics are broad. Maybe he comes from a background of mustangs...
I feel that "haven't been around cars much, eh ?" is jumping to conclusions.. I had a long rant about that but I will leave it alone. You are correct though, bottom line
#12 | |
-I'm- jumping to conclusions ? thread title is 'The Yaris Sucks.' lmfao kthx |
#13 | |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
#14 |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
#15 | |
IMO, it's a sad state of affairs that some no longer know how to perform some very basic service and now rely on all the atomatiic "idiot" equipment on cars. Last edited by RedRide; 10-13-2011 at 06:25 PM. Reason: spelling |
#16 | |
Its mostly the serpentine belts that connect all accessories (A/C comp, P/S pump, and alt.) have the spring loaded tensioner. I have only had to tighten my belt one time after replacing it on any car. As CTscott says, usually a week after replacing when the belt finally stretches to its limits. I just examine the belt during oil changes to see if it starting to dry rot. Then I would consider changing it, not tighten it more.
#17 |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
My bet is they over-tightened it too, I've never had to tighten mine.
#18 |
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
I changed mine at 190k so i cant complain, well actually adjusting it afterwards was a lil pain...
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Persuade me to buy a Yaris! | TONIZZLE | General Yaris / Vitz Discussion | 48 | 09-09-2011 11:31 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
