Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 11-15-2011, 03:08 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Clutch feel on the TS
hey guys
just a quick question , how does your clutch grab and transition between gears feel ?
is it a smooth gear change , or does it bang into gear each time?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 11-15-2011, 03:24 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
SMOOTH as silk...
Old 11-15-2011, 03:36 PM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
ah ok ... then i suppose mine is right ,after i did half the exhaust setup the car use to bang into gear under throttle , meaning i accelerate , the depress the clutch , engage the gear , the release and it kicks you quite hard into the seat as soon as you accelerate ... lately though its doesn't kick as hard into the seat , but the car still pulls well though ... just really weird.
JDMtuner
www.jdmtuner.co.za
Old 11-17-2011, 05:44 PM   #4
SMOOTH as silk...
You have a TS? Or is our clutch the same as what he has?
Old 11-17-2011, 06:23 PM   #5
2ZR-FE
UK Yaris Newbie
Drives: Yaris 1.8 SR
TS in the states i doubt it, explain in more detail about your TS mate and I will let you know how i feel about my 2ZR-FE!
2ZR-FE is offline   Reply With Quote
Old 11-20-2011, 01:44 AM   #6
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
ok , here is before
say you pull away 1st to 2nd , 3rd etc , when i give it some gas , as i depress the clutch , change gear , then release the clutch use to grab quite hard , as you let it go completely it almost kicked you into the seat as you accelerate again.
at the moment ..
1st and 2nd feels almost the same but in 3rd when i release the clutch it is very smooth and not clutch kick at all ...
any idea's ?
is the clutch just worn in nicely ?
also under high speed the clutch engagement is totally smooth and clutch kick is felt , good or bad ? before there was more clutch kick ..
JDMtuner
www.jdmtuner.co.za
Old 11-21-2011, 02:03 PM   #7
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
any other TS owners wanna add ?
JDMtuner
www.jdmtuner.co.za
Old 11-21-2011, 05:51 PM   #8
rayy
Drives: sr
mine bangs into place as if it suddenly started to work.
not sure if its just me but the 2zrfe engine seems to be very very loose, seems to have too much movement when changing gears, i can feel the engine rock back when ever the loads is taken or apply back onto the drivetrain
rayy is offline   Reply With Quote
Old 11-22-2011, 11:39 AM   #9
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
mine use to bang in quite hard aswell , but is a little smoother now for some reason , still "kinda" bangs in but it ALOT smoother , not sure if it should be like that or not ?
i know the 2zrfe in the TS has a metal bar connected to the engine and the engine mount to stop it from rocking , maybe the feeling you getting is the clutch engaging hard ?
in 4th and 5th the clutch still engages quite hard just really 2nd and 3rd seems soother , not maybe sure if its the cars revs climbing a little smoother cause the engagement to be smoother ? possible ...
JDMtuner
www.jdmtuner.co.za
Old 11-22-2011, 11:41 AM   #10
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
what mods do you have on your car ?
now that i think about it , it could have felt smoother in stock form , before i did exhaust and intake ... not 100% sure though
JDMtuner
www.jdmtuner.co.za
Old 11-22-2011, 02:27 PM   #11
rayy
Drives: sr
None at the moment but tomorrow il will be installing a k&n tycoon and d2 coilovers. It maybe my driving style.
Old 11-22-2011, 03:23 PM   #12
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
nice !!! be sure and post the results ;-)
JDMtuner
www.jdmtuner.co.za
Old 11-22-2011, 03:24 PM   #13
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
you gonna love the intake !
JDMtuner
www.jdmtuner.co.za
Old 11-28-2011, 10:12 AM   #14
2ZR-FE
UK Yaris Newbie
Originally Posted by aucorium View Post
ok , here is before
at the moment ..
any idea's ?
The clutch kicks when changing at high rpm, down low rpm its very smooth though, sometimes it almost jumps into second gear when racing the engine in first! What the hell does that mean lol?
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
