Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 12-09-2011, 02:57 PM   #37
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
Originally Posted by syntax View Post
@ mamang as per info at experience ni yaross at marble, if under 60K pa or 2 years at napatunayan na defective na ung battery, papalitan ng toyota.
sidenote: tagal mo naghibernate mamang.. miss u
marble_bearing is offline   Reply With Quote
Old 12-10-2011, 05:47 AM   #38
levanz2007
levanz2007's Avatar
Drives: 2007 toyota avanza G m/t
at least three years of continuous usage sa car bago ma dead, yun eh kung stock ang car kung madaming bling bling then ur battery life will be dead fast...
levanz2007 is offline   Reply With Quote
Old 12-10-2011, 06:16 AM   #39
syntax
syntax's Avatar
+ 1
kailangan na ng grounding kit at voltage stabilizer. . .
Old 12-11-2011, 12:04 PM   #40
levanz2007
levanz2007's Avatar
http://imageshack.us/photo/my-images/64/wheels16s.jpg/
mga sir's saan kaya meron sa area ng Khobar or Dammam may nag popolish nito???? sayang naman kapal pa naman ng lip ganda tignan, benta lang sa akin ng SR 600 ang apat.... and how much kaya pa polish para kuminang na kulay silver... R16, 6.5W, PCD 100/4
Old 12-11-2011, 12:05 PM   #41
levanz2007
levanz2007's Avatar
Old 12-11-2011, 12:30 PM   #42
levanz2007
levanz2007's Avatar
benta naman sa akin ito SAR 2,500 mura nakaya ito mga sir??
15" Rota Flight
-Size: 15x6.5
-Pattern: 4x100
-Offset: +40mm
-Hub Bore: 73mm
-Weight: 15 lbs
fitted w/ Nankang UltraSport NS-II 195/55R15 (98% threadlife) tires
Old 12-11-2011, 01:06 PM   #43
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
15" Rota Flight
-Size: 15x6.5
-Pattern: 4x100
-Offset: +40mm
-Hub Bore: 73mm
-Weight: 15 lbs
ganda ng offset
not sure sa price, pero parang reasonable naman wait natin ibang kayaris
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 12-11-2011, 11:51 PM   #44
syntax
syntax's Avatar
15" Rota Flight
-Size: 15x6.5
-Pattern: 4x100
-Offset: +40mm
-Hub Bore: 73mm
-Weight: 15 lbs
ok ang price pre' sa palagay ko panalo ka na, sa presyong 2500, mags pa lang un...bale freebie na ung tires, saktong sakto ang offset at size nyan. . .
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 05:36 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
