![]() ![]() Drives: yaris Join Date: Jan 2010
Constant 12v power locks
I am going to be installing power locks on the two front doors of my 2008 sedan. It is a universal kit with remote unlock and just wondering where I should get the 12v from. I would like to put the module on drivers side panel. Thanks
#2 | |
Use the location on the under dash fuse panel that I show in my remote start DIY. Power locks require a significant amount of current (15+ A), so using that location works well, as it has the ability to feed up to 60A. http://www.yarisworld.com/forums/showthread.php?t=24860
Mr. 155 and climbing
or get a reeeealllllyyyyy long extension cord to the house
Can i use this female connector for my needs and do i connect to the top pin or the bottom or does it not matter as they both have 12v coming from them.thanks
You can use one like that however be sure that you pick up the one with a sheath. What gauge wire did your kit come with or what gauge do you plan on using?
This is the kit i got on ebay.....Does not have any info just a shitty diagram of what goes where.....
http://www.ebay.ca/itm/190631927472?...84.m1497.l2649 |
I just compared the wire to another i have and it looks like it is 16 gauge. So do i connect this to top pin or the bottom on the fuse panel spot that ctscott said to put it.
The top one. The bottom isn't connected to anything.
Cool thanks for the help guys....
| Question about Power Locks | absolution8 | General Yaris / Vitz Discussion | 3 | 05-30-2011 06:20 AM |
| Power windows and locks on a 2009 3dr. | chilly79 | DIY / Maintenance / Service | 8 | 12-15-2010 12:55 PM |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Where can i get constant power from? | Syroyizhka | General Yaris / Vitz Discussion | 7 | 04-29-2009 11:08 PM |
