Old 03-07-2012, 08:04 PM   #271
Nicfin
Nic
Drives: 2008 3-Door Liftback Manual
I am still in the process of preparing to install the OEM cruise control on my 08 liftback. I was going to use tap splices for the blue and white wires that attach to the plug under the fuse box, which are for the clutch cancel. I was wondering if it was possible to pull the plug and push out the blue and white wire connectors from underneath? If so, I could solder a wire to the very top of each connector without affecting anything else and then reinstall it.
Does anyone know if the little connectors in the plug have a release mechanism? I figured they are not made to remove, but I thought perhaps Scott or someone else might know.
Nicfin is offline   Reply With Quote
Old 03-07-2012, 09:44 PM   #272
The pins are removable. You have to use a small flat object and slide it along the top edge of the pin to release the plastic locking tab that keeps the pin from sliding out.
Old 03-07-2012, 10:39 PM   #273
Nicfin
Nic
Scott, thanks for the quick reply.
That's good to know. Maybe when I can find the time, I can get it installed.
Old 03-17-2012, 08:13 PM   #274
DocZ
Drives: 08 HB
DIY cruise
where can I get the terminals for the ECM and for th spring switch hook ups?
Thanks
DocZ
DocZ is offline   Reply With Quote
Old 03-31-2012, 10:18 AM   #275
kadir2538
Drives: yrais 2008 hatchback
my airbag has only one hole.
i do not know how to take it off.
kadir2538 is offline   Reply With Quote
Old 03-31-2012, 02:38 PM   #276
kadir2538
i have turkish 2008 yaris 5 door hatchback.
i cehcked the clutch has switch orijinally.
i think i only need to install the stalk and i need cable for the horn.
the problem that i have is that everyonbe says you gotta take 2 screws off to take off the airbag. but, my car only has one hole and i do not any screws.
help please!
Old 03-31-2012, 09:31 PM   #277
help please!
For 2006-2011 Yaris, only US/Canada Yaris have the cruise control function build into the ECM, so you would need to install a complete aftermarket system to have cruise on yours.
Old 04-04-2012, 10:05 AM   #278
kadir2538
but, i checked it has switch of the cluch. can you tell me what it means?
and cen you explain how to take air bag out. cos it has only one hole.
and there is no any screws in that hole.
Old 04-04-2012, 11:46 AM   #279
On a cruise control equipped one there will be two separate switches on the clutch. The one that is there now, keeps the car from starting unless the clutch is fully depressed.
The definite test to verify if your car can have OEM cruise control is to check the voltage on the ECM pin 40 of connector A21 (my DIY shows the detailed location of that pin). If there is 12 V on that pin with the ignition in the ON position then the ECM supports cruise control. If you do not see 12 V on that pin, then it does not.
Old 04-04-2012, 01:05 PM   #280
kadir2538
MY CLUTCH has two switch one is down the other one is up.
and can you tell me where the ecm is?
Old 04-04-2012, 01:45 PM   #281
Under the hood against the firewall. My DIY in the link below shows where it is, what it looks like, and where the pin is to check:
http://www.yarisworld.com/forums/showthread.php?t=33750
Does your Yaris have steering wheel audio controls?
Old 04-04-2012, 01:50 PM   #282
kadir2538
my ecu is different.
small socket has 36 pin and big one has more than 60.
and my ecm 2line of pins. yours has 3 line pin.
Old 04-04-2012, 01:51 PM   #283
kadir2538
yes it has audio control.
Old 04-04-2012, 01:54 PM   #284
kadir2538
that is photo of my steering wheels
as you see it on the picture the socket for the cruise control is empty.
and it has just one cable for the airbag.
(would add a pic. but i donot no how to add.)
Old 04-04-2012, 01:56 PM   #285
kadir2538
turkish yaris 2008 cruise control installl
here is the pics.
Old 04-04-2012, 01:57 PM   #286
If you do not have the 1NZ-FE 1.5L engine, then your ECM will be different. Also, only the 1NZ-FE ECM has the built in cruise control function.
Old 04-04-2012, 02:05 PM   #287
kadir2538
my car is d4d
Old 04-05-2012, 06:31 AM   #288
kadir2538
there is no place to install stalk on steering wheel.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
