Old 04-03-2012, 01:05 AM   #1
vincentg
vincentg's Avatar
Drives: Toyota Yaris 2007
Changing the tail light
Hello Yaris World! Im new here and i just got my 07 yaris last month. and it seems the back up light is not working. I already bought the bulb needed through the other thread. And i wanna change it myself (for more bonding experience with the car) any help would do. I already searched the whole forums regarding and there is no step by step process how to put it out.
Thank you guys
UPDATE
now that ive checked the reverse light. i found out that the bulb is in good condition (i switched it to the other side to check if its still working. and it still works just fine) now i need to know how to fix the terminal or how will i find the problem? ive searched tons of PDF files and manuals but nothing to do with the reverse light condition. anyone please do help me.
if i can still fix this or should i call the electrician regarding this.
JUST DRIVE
Last edited by vincentg; 04-05-2012 at 04:24 AM. Reason: found it! but new problem arises
vincentg is offline   Reply With Quote
Old 04-03-2012, 11:20 AM   #2
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
If you have a hatch, open the hatch. On either side you should see a panel that looks like a vent. If you use a flat head screwdriver and pry the top out, it will come off exposing the back-side of the light. You will be able to change the stop + reverse lights from here. The turn signal will require you to unscrew the light housing.
devinlamothe is offline   Reply With Quote
Old 04-03-2012, 11:43 AM   #3
vincentg
vincentg's Avatar
thank you!! :) yes yes! its a hatchback! thank you sooo much
JUST DRIVE
Old 04-04-2012, 08:07 PM   #4
vincentg
vincentg's Avatar
okay. now i checked the reverse light (the left side) and its not the bulb that has a problem, its the connection to it. the terminal or the wiring perhaps. is there anyway i can DIY this?
JUST DRIVE
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
RS Tail Light Maybskee? xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 5 10-21-2010 03:26 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
FREE: Left side tail light 07 Yaris LOCAL ONLY yrsdrgn Items for Sale by private party 8 02-08-2009 04:09 PM
