Old 04-05-2012, 08:54 AM   #289
kadir2538
Drives: yrais 2008 hatchback
miine is
1.4 liter D-4D 90 – 1ND-TV
kadir2538 is offline   Reply With Quote
Old 04-05-2012, 08:58 AM   #290
kadir2538
anyone knows how to close my seatbelt warning sound?
Old 04-05-2012, 09:27 AM   #291
Originally Posted by kadir2538 View Post
there is no place to install stalk on steering wheel.
That is correct. The 2nd generation D4D definitely did not have the factory cruise control.
Old 04-15-2012, 10:57 AM   #292
tytrykowski
Drives: 2007 yaris s
2007 yaris cruise control
have a 2007 Yaris Sedan (S) and I want to get cruise control installed, the engine is a 1.5 DOHC 16 valve EFI VVT-i 4 cylinder. Can anyone tell me if I can install original CC as oppsoed to aftermarket?
Tags:
tytrykowski is offline   Reply With Quote
Old 04-15-2012, 10:59 AM   #293
tytrykowski
Tags:
Old 04-15-2012, 02:55 PM   #294
5thhorseman
Drives: 07 yaris sedan polar white
search
Just search cruise control,there is a diy stick on it.
5thhorseman is offline   Reply With Quote
Old 04-15-2012, 03:18 PM   #295
Tags:
Look at my DIY for 06-11 cars, linked on the first page of this thread. I have the stalk and wiring components for sale if you are interested.
Old 04-21-2012, 12:47 AM   #296
xorrbit
Drives: 2007 Yaris 5-door Liftback
Hey everybody,
I'd like to do the switch cruise control mod to my 2007 AT Canadian Yaris. From reading all these threads it looks like I'll need the Indicator Module, 2 Connector D3 pins, and an ECM connector A21 pin. The switches and resistors and such I can source myself. I have a neat idea for the switches themselves and will post some pics once I get it all installed and hooked up :)
BTW Thanks a ton for making these DIY guides and making everything so easymode for someone like me wanting to do this. When I bought my Yaris last year (used) the only thing that I was not happy about was it didn't have cruise control. I couldn't believe when I stumbled across these forums that the ECM had this functionality all along. My daily 25km each way commute isn't that bad but CC will make it oh so much better.
Cheers,
-Andrew
xorrbit is offline   Reply With Quote
Old 04-22-2012, 09:33 AM   #297
Woodsman
Drives: 2010 Yaris Hatchback CE
With the demise of my Yaris (wife wrote it off) I bought a 2011 Matrix. No Yaris available at the time & the rental from insurance running out.
Is this DIY modification possible on the 2011 Matrix?
Woodsman is offline   Reply With Quote
Old 04-22-2012, 09:36 AM   #298
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Hopefully someone will correct me if I'm wrong but I believe the only thing needed on the Matrix (2006 and up I believe) is the stalk. Everything else is pre-wired.
I was considering trading in the Yaris for a Matrix for some time and this was one of my wonders as well.
I do not know about setting up a custom switch alternative to the stalk using the instructions in the thread though.
teddy is offline   Reply With Quote
Old 04-22-2012, 09:48 AM   #299
Woodsman
I hope your right.
The "custom switch" set-up was my intention.
Old 04-22-2012, 10:13 AM   #300
I hope your right.
The Matrix uses the same stalk, so the custom switch method will work as well.
Old 04-22-2012, 10:18 AM   #301
Woodsman
Thanks.
Old 06-04-2012, 08:26 AM   #302
davidei92
Drives: toyota yaris d4d 90 hp
Hello guys, I'm Italian and I own a toyota yaris d4d 1.4 diesel (90hp). I want to install cruise control, but I have no idea how to do it. I ask help to you because you are an expert, and you will tell me =) sorry my english =)
davidei92 is offline   Reply With Quote
Old 06-04-2012, 08:29 AM   #303
For the D4D there is not an easy way to add cruise control since Toyota did not program it into the ECM.
Old 06-04-2012, 09:48 AM   #304
davidei92
so there is nothing to do? = (
Old 06-04-2012, 10:07 AM   #305
I have read that people have had the AP800 installed on D4D Yaris. I read that it cost about $800 USD.
http://www.conrad-anderson.co.uk/cru...isecontrol.htm
Old 06-04-2012, 10:13 AM   #306
davidei92
sorry but what the AP 800?
But buying the same pieces so it does not work? what is the difference between use and europe?
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
