Old 02-19-2012, 05:11 AM   #73
menz
Drives: yairs blue 2007 automatic 1.3
I did 255 thousand kilometers that is around 158 thousand miles. The engine is still running strong and my auto transmission. I drive mostly on highways. My issues started after 200 k. thermostat, front bearings and fuel pump and filter. That is all I had issues for now.
menz is offline   Reply With Quote
Old 02-19-2012, 06:39 AM   #74
detroiter
detroiter's Avatar
at about 128,000 miles and so far I've had to replace the water pump only, as far as anything crapping out on me. I've had the SRS light coming on and off lately but the car drives just fine, so I'm not going to worry about it for the moment. Never hit anything with the car so I can't understand why the SRS light would be coming on.
Old 03-20-2012, 02:59 AM   #75
nookandcrannycar
208,193 miles on mine....only tires at 70k, an air filter change, and oil/filter changes until replaced front wheel bearings at almost 111k. Since then only Battery at 138k, tires again at 140k, headlight and rear plate bulbs once each between 140k and 171k, alternator at 159k, oil/filter changes, serpentine belt and rear brake adjustment and cleaning (front and back brakes only 20 percent worn) at 207,135 miles...and bought some 50-50 coolant mixture at the stealership (belt and brake adjustment not at stealership) and added coolant to bring overflow reservoir to proper level. I bought 4 spark plugs at the stealership yesterday (Denso iridium) and will have the belt and brake adjustment place put them in....then back to a stealership for an engine air filter that I'll put in myself.
Old 03-20-2012, 03:33 AM   #76
broody
Drives: Yaris 3dr 2009
We have only one yaris at work with around 100 000 miles (100% of city driving). The older they get, the shittier they get too, so we try to avoid the older cars and the recent ones are quickly making more mileage.
The cars are beaten, so many parts were changed.
broody is offline   Reply With Quote
Old 03-20-2012, 10:22 AM   #77
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I'm at 250,000km and nothing majorly wrong (knock on wood) yet. I do have the ABS issue but that's it other than normal maintenance.
Synthetic oil is not just a myth for offering better performance than crude oil. I've posted some advantages below. I've bolded MY personal reasons for switching to synthetic based on my own situation (taken from Wikipedia):
  • Measurably better low- and high-temperature viscosity performance at service temperature extremes
  • Better chemical & shear stability
  • Decreased evaporative loss
  • Resistance to oxidation, thermal breakdown, and oil sludge problems
  • Extended drain intervals with the environmental benefit of less oil waste.
  • Improved fuel economy in certain engine configurations.
  • Better lubrication during extreme cold weather starts
  • Longer engine life
  • Superior protection against "ash" and other deposit formation in engine hot spots (in particular in turbochargers and superchargers) for less oil burnoff and reduced chances of damaging oil passageway clogging.
  • Increased horsepower and torque due to less initial drag on engine
devinlamothe is offline   Reply With Quote
Old 03-25-2012, 06:45 PM   #78
Tardis
Tardis's Avatar
Drives: 2007 Yaris Hatchback
302,000 Km
Just tore a CV boot. GRRRR
Tardis is offline   Reply With Quote
Old 03-26-2012, 06:24 AM   #79
SolidGamble
SolidGamble's Avatar
Drives: 2007 Yaris Sedan
99500 miles. Rolling over 100k very soon.
SolidGamble is offline   Reply With Quote
Old 04-02-2012, 03:33 PM   #80
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
Its nice to see this car lasts. I love mine and don't really have a "dream car" or anything I want to upgrade to. I hope to keep my car until isn't un-drivable!
wiirenet is offline   Reply With Quote
Old 04-02-2012, 04:37 PM   #81
devinlamothe
Originally Posted by Tardis View Post
302,000 Km
What happened? Wear? Hit something?
I will have to inspect mine tonight ...
Old 04-02-2012, 06:01 PM   #82
bronsin
bronsin's Avatar
302,000 Km
Was it origional and did it have 300,000 km on it?
Better do the others if so they cant be far behind.
Old 04-04-2012, 12:51 PM   #83
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Just turned 100K. on 08 sedan
2 major side swipes, fixed on insurance dime.
Occasional CEL for Throttle Position Sensor since new,had it replaced under warranty but cel still throws a P2121 every once in a while,just clear it with Scangauge.
Fully loaded with family right rear bottoms out on bumps..
Great economical Daily driver but my 05 Echo is more trouble free
Have Yaris will travel..
Old 04-17-2012, 09:31 AM   #84
lilerd
Drives: 2008 Yaris 3D HB
Just hit 160,000 miles 2 weeks ago. 2008 HB.
lilerd is offline   Reply With Quote
Old 04-17-2012, 02:49 PM   #85
OH yaris
Drives: 07 hatchback + 06 EVO9
103,000+ on 2007 HB with M/T.
OH yaris is offline   Reply With Quote
Old 04-17-2012, 10:07 PM   #86
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Just hit 100,000 miles on '07 sedan M/T. Changed water pump after about 50,000, no other problems.
goliath1812 is offline   Reply With Quote
Old 03-27-2013, 08:24 PM   #87
xorrbit
Drives: 2007 Yaris 5-door Liftback
Just hit 100k on a 2007 Liftback AT, no real issues yet \o/.
xorrbit is offline   Reply With Quote
Old 03-27-2013, 09:39 PM   #88
racerb
My Blazing Blue '10 HB just turned 104,000 and getting ready to replace original struts/shocks even though their still good! Oh and it still has the original Hankook tires on the rear!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-27-2013, 11:36 PM   #89
nookandcrannycar
racerb
Amazing. And I thought I was doing well getting 85,009 miles off my last set of Firestone FR710s
Old 03-28-2013, 12:15 AM   #90
Hershey
An acquaintance has a 2010 3 door base with the automatic and going on 140,000 miles . Used for his business .
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 01:40 PM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 06:51 PM
Japanese Mix Club Los Invitamos!!! TunTun_yariS[PR] Caribbean 0 12-12-2006 01:03 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
