Old 05-09-2012, 10:10 AM   #1
david_827
Drives: 07 Yaris Sedan
Performance Parts for an Automatic
Hello all. I looked all over the forum but didnt find anything similar to this. I just purchased an 07 yaris sedan, unfortunately i got an automatic. Are there any performance parts i should start with, or am i wasting my time because im driving an auto?
david_827 is offline   Reply With Quote
Old 05-09-2012, 10:44 AM   #2
All the suspension parts are identical so for cornering and stopping, you can do everything the liftback guys do. Springs/Shocks/Struts/Coilovers/Bracing/Sway Bars/Brakes/Etc.
Go-power you can do intake, exhaust, crank pulley, and there are a couple of supercharged and turbo guys with auto transmissions.
Check out our store and I am happy to answer questions (along with a bunch of people on here) about how to make your car perform better.
Old 05-09-2012, 12:12 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
only difference is with the auto you don't have to worry about shifting. Besides that you can do everything else just the same.
Colin Chapman disciple
Old 05-09-2012, 07:41 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Except for light flywheels and grabbier clutches. =)
Old 05-09-2012, 07:56 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
mmmm good.
-Type 07 FFL-
My odometer 03/11
Old 05-11-2012, 05:05 AM   #6
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
You can shift a auto......I do least. But you have the optoin of not ALWAYS shifting
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 05-11-2012, 12:34 PM   #7
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You can most certainly make performance improvements on your car's handling. Since our Yaris is just used for basic transportation, rather than trying to make it faster, I focused instead on making it more roadworthy with wheels, tires, and suspension improvements.
Old 05-11-2012, 06:28 PM   #8
MadMax
MadMax's Avatar
Originally Posted by Qmobile View Post
You can shift a auto......I do least. But you have the option of not ALWAYS shifting
That's my mantra!
Old 05-16-2012, 09:59 PM   #9
david_827
how do you manage that exactly??
excuse my newness, this is the first car thats actually mine and i can fool around with
Old 05-16-2012, 11:23 PM   #10
Qmobile
Qmobile's Avatar
simple! start in "L" wait till you get to the top of the gear(it's noticeable) the go to "2" and so on and so on. I found actually by doin this it adds a tad of accerlation when doin this way vs regular "D". If you want the shift speeds or "points" I can find out for you tomorrow.
Old 05-20-2012, 11:08 PM   #11
Qmobile
Qmobile's Avatar
well here they are. startin for L:
2- around 39/40 mph
3- around 60/70 mpg
D- around 100
I usaully shift from 3 to D quickly bc well I run in the city or on the E-way a lot. Only reason how i know the last shift point is bc i live out in the country. Also for the shift at "3" 60 is where i usually shift but 70 is the top of the gear
Old 05-26-2012, 09:38 PM   #12
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
^ Was gunna say just look at the RPM's but 3dr yaris don't have them :P
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 05-27-2012, 04:27 AM   #13
Qmobile
Qmobile's Avatar
well the "S" has a stock tach.....I got the base so yea
Old 05-30-2012, 05:28 PM   #14
why?
why?'s Avatar
Drives: Yaris LB
tach is one of the easiest things to install. 2nd mod I did on car.
Old 05-30-2012, 07:44 PM   #15
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
^ or you can just get a scanguage II and and have more information displayed.
Old 05-30-2012, 09:18 PM   #16
roneezy360
roneezy360's Avatar
Drives: Toyota Yaris 2007
Shifting an auto wont damage your vehicle in any way will it? I actually tried this out today and its kind of fun, but I looked it up online and was told its better to get a manual valve body and doing this will wear out my transmission faster because of all the heat.
roneezy360 is offline   Reply With Quote
Old 05-31-2012, 11:22 PM   #17
why?
why?'s Avatar
Drives: Yaris LB
It certainly cannot help it. The car just wasn't designed for it, and more importantly the computer wasn't either.
Old 06-02-2012, 07:03 PM   #18
Qmobile
Qmobile's Avatar
then why dose it have the other gears?
07 YARIS Liftback FOR PARTS benjomothians Items for Sale by private party 12 02-07-2012 02:53 AM
OEM PARTS NEEDED!!! JBougie Willing to Buy by private party 5 09-16-2011 02:37 PM
07 YARIS Liftback FOR PARTS benjomothians DIY / Maintenance / Service 0 03-28-2011 02:10 PM
Oregon intrudce Bill to Prohibit Sales of Aftermarket parts IllusionX Off-topic / Other Cars / Everything else Discussions 10 02-14-2009 10:29 PM
Aftermarket Parts Interest? Fluid Motorsports General Yaris / Vitz Discussion 27 11-09-2008 01:00 PM
