Old 07-02-2012, 11:09 PM   #1
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Misfire into multiple cylinder!
Till last week something started. Sometimes when on low-mid load, the engine feels like it cut-off for a second only, and it started to bug me. I was still able to drive it normally without major problem.
I though it was my MAF getting too dirty, so I cleaned it. It did not cure the problem and Im not sure if it helped. Car was still driving perfect except that little cut-off.
Today, I started to intall my oil cooler. I did not finish the job because of a malfunction in a part. So I simply put back my oil filter and some intercooler piping on.
Batterie was plugged all the time.
I cutted, I grinded, with 2 tools, a grinder and my dremel.
And I played with my oil filter...
Those things are the only one I did... This morning I start the car and it runs like a Cam'd muscle car or a subaru.
3 CEL; P0300, P0302, P0303, well I think they are all missfire into one or multiple cylinder.
Could I have damage something electrical? Coils, or the FIC? Maybe a fuse? Because I used my electrical tools on the car.
This morning when my car was missfiring like shitt, I started by removing all intercooler piping, clean the inside, reclean the MAF.
Now the problem is almost gone, I can take-off from the first gear, and the engine idle a lot better. But it is still not good, on load it look like it missfire/cut-off.
I will try to change that MAF for a new one, also I think it would be good to change my O2 sensors they are old as hell.
maxthehax is offline   Reply With Quote
Old 07-03-2012, 12:06 PM   #2
maxthehax
maxthehax's Avatar
UPDATES
This morning the car was bad as hell, missfire into multiple cylinder again. P0300, P0302, P0303, P0304...
I simply removed my AEM FIC, replugged like OEM, the car runs fine now but very very rich! The stock ecu cannot take my 370cc injectors
So I think my FIC was the problem...
I will reinstall my stock injectors, or I will simply fools my plugs running that rich. 10:1 AFR on low low low load... haha 12:1 idle
Old 07-03-2012, 01:36 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
those things are always having issues. So many units have problems. Hope they send you a new unit.
Old 07-03-2012, 02:46 PM   #4
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Do you have the plug and play or is it wired in?
Old 07-03-2012, 09:59 PM   #5
maxthehax
maxthehax's Avatar
I have the plug n play harness... Thats why it took me 5 mins removing it and plugging the oem back.
I need to find out whats the best standalone ECU to get for my car, it seems to be so big of a job...
I lost so much power all over my rpm/load range without the FIC, thats incridible!...
Old 07-04-2012, 10:36 AM   #6
Yoda
Yoda's Avatar
It might be the unit but most issues with it are due to wiring it up. But you have the pnp harness so I don't know. I heard sone had problems with the boomslang harness tho. Ask Scott
Old 07-04-2012, 01:28 PM   #7
maxthehax
maxthehax's Avatar
I ran the FIC for a year now, It was fine until about a week. And a morning it simply wont work like I described in first post...
Anyway I would just like to learn more about the work implicated into installing a full standalone ecu on my car. I dont want to plug a piggyback again...
Unfortunatly there is no documentations about installing lets say a universal EMS on my car...
Old 07-19-2012, 09:42 AM   #8
maxthehax
maxthehax's Avatar
I have updates;
Even if my FIC worked ``fine`` for a year before messin up, I decided to take a close look at the wiring. Lets says the lack of PLug N play standalone system and their very high prices make me think about it a couple days. I come to the conclusion that I already spent enough and I have other project in life (dont worry I still love my car like before! lol)
So to make sure I have a 100% correct connections I decided to buy a PLUG N PLAY harness for the scion xb, sold by dezod.
I will give more infos when I receive that harness and try it out!
Old 07-20-2012, 07:42 PM   #9
^ You didn't buy from us?
Old 07-20-2012, 07:44 PM   #10
Even with custom wiring, I believe you can use the Null connectors that come with the FI/C and disable it. I did that on mine before my tuning was done.
Old 07-20-2012, 08:44 PM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup....I am still using my bypass since I can't seem to idle for shit with this replacement motor. Using same maps as other motor which would idle fine, yet with this one it won't. Stupid.
Old 07-21-2012, 08:23 AM   #12
maxthehax
maxthehax's Avatar
Lol, do you really make a plug n play for the echo?
I though you were but for the Yaris...
Updates;
My package just passed the Canada border. I should reveice it during the week.
I feel a lot like I will plug everything and it will still be the same lol. At least I will know its not a wiring issue.
Q: Does it happen sometimes that FIC/piggyback unit could lost some datas in memories?
Old 07-21-2012, 11:17 AM   #13
A: It's easy to reload your map, and see if anything changes.
Lol, do you really make a plug n play for the echo? I though you were but for the Yaris...
You're on our forums -- you know we serve all brands of cars and source parts for everyone. If I don't have a chance to earn your business, I can't be a vendor.
Old 07-21-2012, 03:47 PM   #14
maxthehax
maxthehax's Avatar
I understand :P
And dont worry I already rock`s a couple of your parts :P
I just received your new fuel rail, very nice finish. If I can get that FIC working again, it will be my next install.
Btw, off topic, are you able to source me a carbon fiber hood for my echo/vitz hatch?
Thanks
Old 07-21-2012, 05:07 PM   #15
^ I'll check, but probably not from the USA, I don't think we had the Echo hatch here, or very many of them -- maybe someone else knows better than me.
Old 07-23-2012, 11:37 AM   #16
maxthehax
maxthehax's Avatar
UPDATES;
Harness installed. I still get missfiring, I can move the car but not drive it. It runs rough...
I want to plug a laptop on it. What should I look at first if my problem is missfiring?
Thanks!
Old 09-06-2012, 04:50 AM   #17
chaditotx
Drives: 2007 3dr hb 5sp
What do your plugs look like? Coilpacks? Did you nick anything on the factory harness? Crank position sensor?
chaditotx is offline   Reply With Quote
Old 12-10-2012, 11:10 AM   #18
maxthehax
maxthehax's Avatar
Everything was alright... The FIC unit itself was the problem.
I changed to a new unit with the same PnP harness, everything is fine now.
Thanks for inputs everyone!
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire dante2086 DIY / Maintenance / Service 4 05-15-2011 05:36 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 05:44 AM
misfire on no 1 cylinder beemer dave DIY / Maintenance / Service 9 05-25-2009 09:13 PM
