Old 06-15-2012, 08:00 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Home made handling mods/parts???
Are most all of the strut tie bars and chassis stiffeners just mild steel/ aluminum or are they heat treated for some reason I don't quite get? Why don't people just fabricate their own? Voodoo, Santeria, Quantum Physics, Fear of being laughed at?
I kind of get why anti-sway bars are not home-made due to the whole spring issue (heat treating) so I'll be buying that soon.
07stlYaris is offline   Reply With Quote
Old 06-15-2012, 09:11 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I think most of it comes to cost. it probably isn't worth the time and effort to make your own when you can easily buy the ones that are mass produced. my time is valuable, as is most peoples. I work a lot and have a daughter that I love spending time with. I would much rather pay someone to figure out all the mess and just bolt it in place. besides, unless you are really into it, you don't need all that stuff. it is nice to have but most people are good with a sway bar and maybe a few extras.
just my 2 cents
Old 06-18-2012, 05:26 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Even if you were good at working the metals, the prices of what you can get are so insanely low it makes no sense. http://shop.microimageonline.com/Bracing-Bars_c22.htmhttp://www.ebay.com/sch/i.html?_nkw=...aris&_osacat=0
Plus these companies take the time to make sure the part does what it is suppose to, and they have access to computers and software we don't.
Now if you work with the materials in your day job, and are sure you can do it well and quickly, then go for it.
Colin Chapman disciple
Old 06-18-2012, 06:01 PM   #4
It's takes decent welding skill to assemble a part that (1) will fit and (2) won't fail under stress.
Old 06-18-2012, 06:41 PM   #5
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
When we buy manufactured parts from a company, there is something else we receive which comes already built into each product...
...engineered design.
Old 06-19-2012, 02:14 AM   #6
That's true, but for something like a mid-brace for example it's really just a strip of steel with two holes. I totally understand and appreciate the do-it-yourself side of things -- I'll cheer anyone on doing a DIY!
Old 07-08-2012, 09:44 AM   #7
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
I am Doing and testing my own made Cold Air system after finish and fully test i will post it in here, i like to do it on my own way.
***High-Performance Cooling System***http://honda-tech.com/showthread.php?t=3062009
***The Basics of Reading a Spark Plug***
http://honda-tech.com/showthread.php?t=3063102
ALL-TECHwire
Hussain-Vtec is offline   Reply With Quote
Old 07-08-2012, 12:24 PM   #8
tooter
play every day
tooter's Avatar
When it's ready, I'd like to see what you come up with, as I'm interested in intake and exhaust flow designs.
Old 07-08-2012, 01:51 PM   #9
Hussain-Vtec
I will Do That & thank you Tooter for showing the interest.
Old 11-30-2013, 01:20 AM   #10
Sedan
Drives: '08 Manual Yaris Sedan
Hi guys,
Sorry for digging up an old thread.
I was on the hunt for a rear sway bar for a while. But after a while gave up since I was not able to find one of good quality ( judged only by the finishes though) and the quoted prices were not reasonable in my opinion. mind you, Im not in the US.
Came up with and idea of making one for my self. I have a friend with a steel work shop and he said he can make one if specs are available.
So guys if any one has the dimensions, the thickness of the tube, plates and what not. Please share. Also if there are other treatments to be done, please recommend.
Thanks.
Sedan is offline   Reply With Quote
Old 11-30-2013, 02:01 AM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Common tubing sizes. The question really comes down to what rate are you looking for?
5/8"(16mm) solid
3/4"(19mm) .120 wall
1"(24mm) .120 wall
1"(24mm) .095 wall
1.25"(32mm) 0.095 wall
Old 11-30-2013, 02:24 AM   #12
Sedan
Thanks a lot for the quick reply.
Can you explain the value for the wall thickness. Is the value given as 0.120 inches?
Further, would appreciate if you could specify the plate thickness.
Does the shape of the bar play a major role. The three designs Ive seen on the internet have three very different shapes.
Old 11-30-2013, 02:34 AM   #13
xnamerxx
0-60 in slow
xnamerxx's Avatar
Yes the value is given in inches, thats mainly due to tube stock here being referenced in inches rather than in metric. I can't specify thickness since you really need to figure out what bar rate your looking for, which isn't something I can give you an answer for. TRD is a 19mm bar and UR is a 24mm bar beyond that I can't give you any answers.
Bar shape is important, as more bends decreases the effective rate of the bar but it really comes down to fitment, if the bars have to bend to fit, they have to bend to fit.
Here is a link that gives a brief explanation of swaybar design.
http://www.hotchkis.net/_uploaded_fi...ons162file.pdf
Old 11-30-2013, 05:13 AM   #14
Sedan
Thank you very much for the information. Now I have a starting point. Will check with the local suppliers for the available tube sizes.
