Old 08-08-2012, 08:05 PM   #523
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
post pics of when its compressed :)
where did you ran the 6an new feed line.. ? where can i reach the pump assembly ? under passenger seat ?
Interior:ALL red, black roof
Old 08-08-2012, 10:59 PM   #524
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
The pump is under the rear seat under a silver piece of sheet metal. I did shorten the line to the pump a little. That pic was not the final assembly. The line will run under the car and tied to the factory line that I am going to use as the return. I will post some more pics tomorrow if it doesn't rain.
pimp my yaris is offline   Reply With Quote
Old 08-09-2012, 12:34 PM   #525
packetrace
packetrace's Avatar
Good thanks!!!:-)
Fun to follow thread like this :-) will make thing easier when i will install mine /)
Old 08-09-2012, 09:14 PM   #526
packetrace
packetrace's Avatar
wow man....i rmeoved the rear seats(and did not pu them back :D) its BIG this fuel pump assembly!!! i tought I would have some thing that fits in my hand...ITS BIGGG!! ahah...just wanted to share..
Old 08-09-2012, 09:27 PM   #527
^ dunno what you mean. The pump is very small
Old 08-10-2012, 04:44 AM   #528
packetrace
packetrace's Avatar
I meant..nott the pump itself...the cylinder in which it stands...its pretty compare to what i had expected lol
Old 08-12-2012, 11:19 PM   #529
pimp my yaris
C'est la vie
The fuel system is done and WOW what a difference. I now know the stock regulator was seriously choking off fuel and could not flow enough to handle a turbo yaris above 5 psi. The only reason it was working was because of the larger injectors and the fact that I was increasing the duty cycle to max them out. I went from plus 80% fuel at the high rpm end of my map to -12% at the same spot on my map with the new fuel system. My new regulator adds 1 psi of fuel pressure for every 1 psi of boost. This does most of the tuning for you. You absolutly still need a piggy back though. I took more pics of the system and some pics when I was doing some "HOT LAPS" and tuning.
Also as far as parts used: fuel rail, scion TC injectors, Aeromotive fuel pressure regulator, 1/8 npt fuelpressure guage on regulator, 1 -6an bulk head fitting with nut, 6 straight -6 hose end fittings, one 90 degree -6an hose fitting, 1 -8an straight cut to -6an hose fitting with o-ring, one -8an straight cut to -6an with a 90 deg. bend and o-ring, 25ft of -6an black braided fuel line. I bought the line and almost all the fittings from e-bay and the last fitting from summit racing. That one was hard to find.
Old 08-12-2012, 11:21 PM   #530
pimp my yaris
C'est la vie
O, I forgot. The regulator and the fuel filter on the bottom of a car I got from a friend. Still need to pay him.
Old 08-13-2012, 10:12 PM   #531
packetrace
packetrace's Avatar
wow nice!!! thank you for picture!!
so you feed from passenger side...and returns on the driver side to the stock hard line ?
what kind of inline filtrer did you used ?
Old 08-15-2012, 01:43 PM   #532
pimp my yaris
C'est la vie
The feed and return are zip tied together. Yes I am using the stock hard line for the return. It feeds on the driver side of the fuel rail.
I am attaching a manual boost controller and I am going to turn it up to 15psi and retune.
Old 08-15-2012, 02:25 PM   #533
Excellent!
Old 08-15-2012, 02:50 PM   #534
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Did you get a new turbo?
Yoda is offline   Reply With Quote
Old 08-15-2012, 03:11 PM   #535
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You meant 51psi right?
Old 08-15-2012, 03:36 PM   #536
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
you lost me here? i hope you dont mean you going to us the boost controler to bring you fuel pressure up to 15psi because thats not going to work..
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 08-15-2012, 03:52 PM   #537
I think he means boost, not fuel pressure.
Old 08-15-2012, 06:16 PM   #538
scioncrew
scioncrew's Avatar
Drives: SCION tC
I hope so :)
Old 08-15-2012, 06:22 PM   #539
fnkngrv
fnkngrv's Avatar
pretty sure that is the case and I am curious what he is setting his FP at.
Old 08-15-2012, 06:58 PM   #540
pimp my yaris
C'est la vie
Fuel pressure is set at 45psi at idle.
And yes I am increasing turbo boost because that is the whole point of getting enough fuel to support it.
I was beyond maxing the stock in tank fuel pressure regulator at 12psi
I am running into a new problem in trying to get to 15psi. It looks like my current .48AR turbine turbo will not flow enough air to maintain 15psi. I am getting to 16psi now, but as rpm,s go up boost is falling off. Time for a new turbo and a new manafold.
This is what Im liking
http://www.ptuning.com/html/Item-Des...9&ModelDesc=xB
Plus a tial external wastegate and a .64AR hot side turbo with a new custom 3 inch exhaust.
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
