Old 08-13-2012, 12:21 AM   #559
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
O, I forgot. The regulator and the fuel filter on the bottom of a car I got from a friend. Still need to pay him.
pimp my yaris is offline   Reply With Quote
Old 08-13-2012, 11:12 PM   #560
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
wow nice!!! thank you for picture!!
so you feed from passenger side...and returns on the driver side to the stock hard line ?
what kind of inline filtrer did you used ?
Interior:ALL red, black roof
Old 08-15-2012, 02:43 PM   #561
pimp my yaris
C'est la vie
The feed and return are zip tied together. Yes I am using the stock hard line for the return. It feeds on the driver side of the fuel rail.
I am attaching a manual boost controller and I am going to turn it up to 15psi and retune.
Old 08-15-2012, 03:25 PM   #562
Excellent!
Old 08-15-2012, 03:50 PM   #563
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Did you get a new turbo?
Yoda is offline   Reply With Quote
Old 08-15-2012, 04:11 PM   #564
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You meant 51psi right?
Old 08-15-2012, 04:36 PM   #565
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
you lost me here? i hope you dont mean you going to us the boost controler to bring you fuel pressure up to 15psi because thats not going to work..
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 08-15-2012, 04:52 PM   #566
I think he means boost, not fuel pressure.
Old 08-15-2012, 07:16 PM   #567
scioncrew
scioncrew's Avatar
Drives: SCION tC
I hope so :)
Old 08-15-2012, 07:22 PM   #568
fnkngrv
fnkngrv's Avatar
pretty sure that is the case and I am curious what he is setting his FP at.
Old 08-15-2012, 07:58 PM   #569
pimp my yaris
C'est la vie
Fuel pressure is set at 45psi at idle.
And yes I am increasing turbo boost because that is the whole point of getting enough fuel to support it.
I was beyond maxing the stock in tank fuel pressure regulator at 12psi
I am running into a new problem in trying to get to 15psi. It looks like my current .48AR turbine turbo will not flow enough air to maintain 15psi. I am getting to 16psi now, but as rpm,s go up boost is falling off. Time for a new turbo and a new manafold.
This is what Im liking
http://www.ptuning.com/html/Item-Des...9&ModelDesc=xB
Plus a tial external wastegate and a .64AR hot side turbo with a new custom 3 inch exhaust.
Old 08-15-2012, 08:05 PM   #570
fnkngrv
fnkngrv's Avatar
I am still thinking that you should tune for 51 lbs of boost!
Old 08-16-2012, 07:06 AM   #571
packetrace
packetrace's Avatar
Hey pimp...can you explain me why everybody puts the regulator AFTER the rail...
Old 08-16-2012, 08:00 AM   #572
Yoda
Yoda's Avatar
Google
Old 08-16-2012, 08:23 AM   #573
packetrace
packetrace's Avatar
For future reference:
I’m trying to plumb my stand-alone EFI regulator properly, where do I put the regulator, before or after the fuel rail(s), and what ports do I use?
Unlike a standard or “dead-head” carb regulator, which controls pressure between itself and the carburetor inlet, a bypass regulator creates and controls pressure between itself and the pump. Therefore, the correct EFI regulator location is after the fuel rail(s) whenever possible, promoting the required fuel pressure, flow volume and velocity through the fuel rail and to the injector inlet, at all times. Most Aeromotive EFI regulators have two inlet ports, one on each side, and one bypass port, on the bottom. Either inlet may be used with a single fuel rail engine, both inlets with a dual fuel rail. Any unused inlet ports must be blocked with the appropriate port plug. The ideal flow-path is: out of the fuel pump, into one end of the rail; out the other end of the rail, into the regulator side port(s); out the regulator bottom port, back to the tank at the top. Dual rail applications should employ a Y-block to split the supply line before entering the rails, then individual lines are run from the opposite end of each rail to each inlet port on the regulator.
Old 08-16-2012, 11:54 AM   #574
^ Looks to me like you answered your own question.
Old 08-16-2012, 02:32 PM   #575
packetrace
packetrace's Avatar
Yes :)
Old 08-17-2012, 12:14 AM   #576
pimp my yaris
C'est la vie
Ditto ^
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
