Old 08-13-2012, 11:10 PM   #127
sickpuppy1
Drives: 2010 Yaris Sedan
That comparison I used with the Harley? My vehicle weights well over twice what his does and he doesnt get much better mileage than I do......
Old 08-14-2012, 01:09 PM   #128
Idahotom
Drives: 2008 5 sp. LB
Originally Posted by mspeedman View Post
What was your fastest average highway speed and what percentage of your tank was highway driving?
Also, what are your tire pressures?
Best I can get on my brand new 2012 with an napa gold filter and chevron is about 36 mpg per tank @ 80% highway between 70 and 85 mph.
BTW,what is the elevation of the range you drive?
I'm at 14 above sea level; i'm guessing that's why some of you are in the 40's, the air is thinner in OR an WY and the adirondacks...
Anything to get up the MPG's, boy. I'm actually thinking of putting some motorcycle tires on my rear to minimize drag.
Thanks in advance,
You have a point about the altitude. It's the same reason the big jets fly high, thinner air means less drag. Sure the engine makes less power, but so what. I'm at 4500 to 5500, 100 % 0f my local driving, mid 40's everytime but I drive slow, and got a stripped down rig. I could hit 50 I think but for me more trouble then it's may be worth as in time spent.
Idahotom is offline   Reply With Quote
Old 08-14-2012, 02:27 PM   #129
nookandcrannycar
Aha....no wonder KentSzabo has a relatively easy time getting the fuel economy he does.
Old 08-14-2012, 04:33 PM   #130
matti
Drives: 2017 Yaris L (5sp manual)
How accurate is the mpg gauge vs. real mpg on the 2012 Yaries?
matti is offline   Reply With Quote
Old 08-15-2012, 09:19 PM   #131
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The overall average for my 2012 has been 37.5 mpg which is pitiful compared to what some of you guys are getting, but I hit my personal best of 38.9 mpg on the first fillup with the new intake manifold.
Old 08-26-2012, 10:42 PM   #132
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Just did a fill and well nothing spectacular. I got 648 KM and 35.919 litres.
Which is 5.5 L/100 KM ... or 42.76 MPG. This is probably 85% city driving .. and the rest highway. This is very close to my last 3 fills .. which are around 5.4 to 5.6 L/100 KM. So .. very consistent.
I have switched from Shell gasoline (which seems to give me not so hot gas mileage). I am now going to use Esso gasoline and see how that works for me. (ExxonMobil I believe for those in the US).
Anyone have any comments on Esso / Exxon gas ? Is it a good choice ?
edmscan is offline   Reply With Quote
Old 08-27-2012, 08:54 AM   #133
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
I think that is a great average you are getting, especially for city driving...
caper26 is offline   Reply With Quote
Old 08-27-2012, 05:11 PM   #134
edmscan
edmscan's Avatar
Thanks ... I try. But I am just learning ... I am by far not an expert hypermiler.
I try to remember to use DFSO (like when coming up to a red light .. ), but I don't always remember so I think that there is room for improvement.
Old 08-27-2012, 08:40 PM   #135
matti
In the 2012 Yaris, any thoughts on how accurate the average MPG computer is vs. actual calculations? Thanks.
Old 08-27-2012, 10:23 PM   #136
edmscan
edmscan's Avatar
I would think that it is as accurate as a ScanGauge or similar device as I would think that it would use OBDII data as well. But I don't have a 2012, though I cannot see any other method it could possibly use to calculate this figure. I have seen similar readouts in other Toyota cars .. such as the Prius and Venza though they seem to display such things as L/100 KM (Canadian model) and distance to empty.
Old 08-27-2012, 10:51 PM   #137
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
the distance to empty is conservative from what i can tell... it actually reads a lot lower than how many miles you can actually go - yes, i tried lol. as for the mpg readings, i would hope they're accurate?
b20vteg is offline   Reply With Quote
Old 09-04-2012, 03:00 PM   #138
matti
I've run two tanks through the 2012 Yaris L 5M. I'm driving quite carefully and using DFCO a lot. Most of my driving is about 35-45mph, with not much stop and go. First tank was 44.83 mpg and second was 47.12 mpg.
Old 09-04-2012, 03:12 PM   #139
Doing pretty well. If you want more, I think you're only options (for driving technique) would be kicking in DFCO much sooner than you already are or using FAS.
Old 09-04-2012, 03:26 PM   #140
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
personal best was 41.6 but that was 90% highway
Old 09-04-2012, 03:29 PM   #141
matti
Thanks. What is FAS?
Old 09-04-2012, 03:42 PM   #142
b20vteg
no show, no go :(
b20vteg's Avatar
mine's currently around there too. we must be doing something wrong? :(
Old 09-04-2012, 03:49 PM   #143
1.5
Form>Function
1.5's Avatar
IDK I think that is pretty damn good
Old 09-04-2012, 03:53 PM   #144
b20vteg
no show, no go :(
b20vteg's Avatar
how are people getting 45+ mpg? :S
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
New personal record: 53.69 MPG BailOut Fuel Economy Forum 26 08-21-2009 06:31 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
