Old 09-04-2012, 04:55 PM   #145
Originally Posted by matti View Post
Thanks. What is FAS?
iirc, FAS = forced auto stop. Essentially turning off the engine (put the ignition back on "ON" to make sure you still have the ability to turn and brake). It's a little more advanced. If the stop light has turned red way ahead of you, you can use FAS so you're not slowing down as much as you would with DFCO. You can come to a stop and still have the engine off, thus not wasting gas by idling. NOTE: you will only have the ability to have two or three good pumps on the brakes, so use it wisely. If you came to a stop, start the engine again, if not, bump start the engine in 5th. You can also use FAS if you're going down a hill to either keep momentum or gain some speed. FAS uses no gas at all vs the very, very minute amount of gas that DFCO uses.
Old 09-04-2012, 04:56 PM   #146
Originally Posted by b20vteg View Post
how are people getting 45+ mpg? :S
For me, only way I do that is either all freeway driving or using more advance techniques in city since I have pretty heavy rims and tires (41.3 lbs per corner, I believe).
Old 09-04-2012, 04:57 PM   #147
matti
Drives: 2017 Yaris L (5sp manual)
Thanks. I now know that FAS is definitely not for me! Interesting, though.
matti is offline   Reply With Quote
Old 09-04-2012, 04:57 PM   #148
will refer everyone back to this sticky:
http://yarisworld.com/forums/showthread.php?t=5979
I was personally taught by him this one day when he was in Sac.
Old 09-04-2012, 04:58 PM   #149
If you know that the stop light is a long one, you can always shut off the engine when you've come to a stop.
Old 09-04-2012, 05:01 PM   #150
personal best was 41.6 but that was 90% highway
mine's currently around there too. we must be doing something wrong? :(
I'm thinking you guys aren't maintaining a set throttle position (note I didn't say speed). If you're using cruise control, stop. LOL. Cruise control will vary the % of throttle used to maintain the speed.
On the freeway, my instant mpg ranges from 40-60mpg simply because I keep my throttle at 24% and let the road determine my speed. I'll only speed up if my speed dips down to 55mph and let off the gas once I get to 75-80mph. My average speed in my usual Sac to Bay Area commute (about 65-70 miles) is 65-70 mph, usually averaging 45-50 mpg.
Old 09-04-2012, 05:07 PM   #151
That's with an intake, wrong size exhaust piping (2.25"), heavy rims/tires, a sub in the trunk along with a couple basic socket wrench sets, a breaker bar, a torque bar, a pair of shoes, quick detail spray, window cleaner spray, and some microfiber towels. LOL, so I do have a bunch of crap in my trunk, and my exhaust piping pushed my torque curve to the top end where I rarely ever drive. I play my music moderately loud too, so that puts a strain on the electrical system, which possibly uses up more gas (since my alternator is working harder, I'm assuming).
Old 09-04-2012, 05:37 PM   #152
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Im horrible at that. I cannot keep my foot at one level position on the pedal its too heavy lol
Old 09-04-2012, 06:09 PM   #153
nookandcrannycar
If I remember correctly, dollar wise, restarting = 30 seconds of idling. So 31 second + stops with the engine off save money.
Old 09-04-2012, 06:33 PM   #154
matti
I just drive with a very light foot and use cruise a lot. If I'm coming up on a moderate uphill, I'll take it out of cruise, however. I coast up to stop signs, intersections, etc. I haven't done much highway driving, though. My work schedule will soon require me to drive quite a bit more on the freeway: I suspect my mileage will go down, then.
Old 09-04-2012, 06:48 PM   #155
1.5
Form>Function
1.5's Avatar
I could get better mileage if I didnt have to slow to a crawl to pass over bumps and train tracks lol.
Old 09-04-2012, 06:58 PM   #156
I come to a crawl at speed bumps, driveways, and train tracks too.
Old 09-04-2012, 07:00 PM   #157
If it's a short time on the freeway, yes, your mileage will go down from having to speed up to freeway speeds. But if you'll be on there for a while, you should still have the same, if not, higher mpg's.
Old 09-04-2012, 07:01 PM   #158
Brian told me it was like 7-8 seconds. No clue. I only turn off my engine if I know I'll be at a light for at least a minute. LOL
Old 09-04-2012, 07:05 PM   #159
matti
Thanks. I'll be on the freeway for about 125 miles at a time. The speed limit is 70mph, but I'm not sure yet if I plan to go slower than that. I'll have to see what my mpgs look like, I suppose.
Old 09-04-2012, 07:13 PM   #160
O_O
That's a long time being on the freeway. Do you have a Scan Gauge II by chance?
Old 09-04-2012, 07:15 PM   #161
matti
O_O
No Scan Gauge II.
Old 09-04-2012, 07:32 PM   #162
ah, hmmm, once you get up to speed, back off the throttle to the point where, if you were taking off in first gear, you would be accelerating slowly.
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
New personal record: 53.69 MPG BailOut Fuel Economy Forum 26 08-21-2009 07:31 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
