Old 09-21-2012, 11:22 PM   #1
chriswf
Drives: Scion tC and Saturn SL1
Paint my steelies white? :D
Hey guys, I ended up getting a Yaris. The car is amazing so far.
I bought a Fit, it seemed slow when I test drove it with me, my wife, and the heavier salesman guy... But I bought it anyway, used, 90,000 miles. Well, 1 day of driving it, -even alone- , it got REALLY SLOW. And bogged horribly.
Honda? Really?
Took it back and got the Yaris with less than half the miles, cleaner exterior, better on gas, and accelerates decently. Same price.
The ONLY problem with my Yaris, is they put chrome hubcaps on it. I don't like it, but I don't necessarily want to get anything bazaar or special either.
I was thinking about taking off the Yaris wheels, and painting them white to match my white Yaris 2d '10 hatchback's paint.
I thought it'd still look decent, here's some other white cars with white steelies.
What do you guys think? Got any photos of Yaris' like this?
chriswf is offline   Reply With Quote
Old 09-21-2012, 11:38 PM   #2
I painted the steelies on my new project Yaris white, when I pulled the super cheesy aftermarket hubcaps off:
Old 09-21-2012, 11:58 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Do it like that first pic you posted - black with white trim.
Old 09-22-2012, 12:10 AM   #4
chriswf
Wow that is a VERY red yaris... I don't think I've seen any red ones where I live. Only black, silver, white, and a few different blue shades.
I do like the wheels though.
If I do just a white ring, should I paint the center black or are they black enough without paint?
Old 09-22-2012, 12:24 AM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
not black enough. Steelies will rust so why not add a little more protection.
Old 09-22-2012, 12:34 AM   #6
chriswf
Any specific brand? Just like Kyrlon or Duplicolor? Lol.
Old 09-22-2012, 04:24 AM   #7
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
white steelies are sex!
b20vteg is offline   Reply With Quote
Old 09-22-2012, 08:51 AM   #8
I use Krylon. My experience is that it goes on better and tends to last better than Duplicolor or Rustoleum. Just do a couple of coats of clear over the white to protect it and make it easier to clean them.
Old 09-22-2012, 09:33 AM   #9
chriswf
Should I scuff the wheels? Like with a scotch bright pad? Or 180 grit? Or 320 grit?
OR is that not necessary?
I used to work in a body shop but I never painted a single wheel - at least not on purpose lol.
And I really don't know how well aerosol paints stick to smooth surfaces.
Old 09-22-2012, 09:55 AM   #10
Definitely, scuff them up. Use 80 or 100 girt sandpaper or one of the coarse scotch pads. Also, use the Krylon primer before the paint. Because of the depth of the indented area, you will get a lot of texture (since the overspray kind of hangs there and gets picked up by the paint). That means that you will need to do some sanding between coats (I usually use a fine scotch pad for that part).
Old 09-22-2012, 01:11 PM   #11
^ With wheels, definitely prep, primer, then paint, or it won't last.
Old 09-22-2012, 11:28 PM   #12
chriswf
For wheels, if I primer them, do I wet sand them with like 500 or 320 like a car?
Old 09-22-2012, 11:35 PM   #13
Depends on how perfect you want them to be, although wet sanding between primer and paint is probably overkill on the steelies, which are pretty crude.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 12-01-2013 12:07 AM
WHITE Yaris paint touch up + silver dashbaord scratch repair marcus25 Wash, Wax, Detailing, Exterior Repairs 1 08-26-2010 01:11 PM
Toyota OEM Paint Code for steelies? Snappy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-07-2010 02:34 PM
Matching spray paint to Polar White jdubau55 Cosmetic Modifications (Exterior/Interior) 1 03-13-2007 07:01 PM
