![]() Drives: 2009 3dr. Join Date: Oct 2008
Help, MI fogs stopped working?
I have the Micro Image fogs wired them up per the instructions I downloaded from their site with provided switch they worked ok. They acted weird, had to start-up car for them to come on, but they stayed on if I turned the car off, and sometimes they didn't want to come on at all.
They worked for awhile and now have gone dead. I looked over the wiring and fuse and everything seems to be good. Any ideas? |
It definitely sounds like you had a wiring issue to begin with, with that behavior. I would start with checking the bulbs, as it could be as simple as them being burnt out now.
There are a couple of different iterations of the MI fog wiring guide. Which did you use?
I used the PDF instructions from the Micro Image website.
Here are a couple pics of the wiring under the steering wheel. Dont worry about the exposed yellow to red wire. I taped it up real good. |
Your pictures did not come through.
should be there now.
![]() FYI I'm using the switch that came with the kit. |
Try disconnecting your wiring and simply jumping the two wires together that were originally in the two upper left locations of the headlight stalk connector. After you do so, as soon as you turn the headlight switch on and to low beams the fogs should light.
Doing that will tell us whether the problem is under the hood or under the dash.
So to be clear, disconnect the green wire and put the yellow wire back where it was originally, and then jump the yellow wire and the tan wire together in the harness?
#8 | |
Correct.
Cool, I'll check it later tonight when I get a chance.
Thanks. |
Drives: Bmw Join Date: Sep 2012
Hi dear am newbie here and i read this topic and i want to say what i know about your problem you should disconnect the green wire and put the yellow wire back where it was originally, and then jump the yellow wire and the tan wire together in the harness?
I finally have some time to mess with this, so I put the yellow wire back and jumped it with the brown one and the lights work. Now what do I do?
OK - That means that the switch wiring or the switch itself has an issue. Can you post some detailed pictures of where the wires go into the switch connector and where you had connected the other ends?
Ok, I have a couple shots here. one of the wires going into fuse box under the hood, and of the wiring connected to the MI switch mounted in my center console.
The pictures in post 3 show where the switch wires went to. |
Modded Moderator
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was clearly service related. I've moved it to the correct section.
Sorry about that i was being lazy. Won't happen again.
CTScott, I found your directions on the how to install with aftermarket switch. Makes so much more sense now. So I'm gonna rewire it inside accordingly. Should I just use a wiretap to connect to the wires on the D4 connector?
#17 | |
http://www.microimageonline.com/down...h%20Wiring.pdf For the connection to the D4 wires, tap splices are fine.
If i had to use a new switch witch wires are power, source, and ground?
| My car's electrical system just stopped working today..? | jamhot18 | DIY / Maintenance / Service | 14 | 11-04-2018 01:40 AM |
| Issue on rostra cruise control. Stopped working!! | marcus | DIY / Maintenance / Service | 1 | 03-25-2012 04:42 PM |
| Fog lights, or parking lights stopped working | sylvermagyk | DIY / Maintenance / Service | 4 | 03-24-2011 05:13 PM |
| Electric Windows Stopped Working !?!? | MattyP | DIY / Maintenance / Service | 0 | 09-14-2010 07:20 AM |
| Help! Horn just stopped working. | steveh74 | General Yaris / Vitz Discussion | 14 | 09-17-2009 10:23 AM |
