![]() Drives: Yaris 2005 Join Date: Oct 2012
Driver Side Mirror - Can This Be Replaced Easily? (Image Attached)
![]() Hi all, Toyota 2005 T3 owner here. Hope you can help. Have done a search but no luck. Annoyingly, someone clipped my driver side mirror and the whole mirror + base came off, leaving just what you can see in the image. Was wondering if I can get a replacement part for this mirror? I cannot just get a mirror to stick on as the whole mirror piece has come off, but it looks like the fittings are in tact. Is there a part out there which I can just snap on? I have seen parts out there that seems to do the job but it's not clear they're exactly right? e.g. http://www.amazon.co.uk/TOYOTA-Wing-...9028092&sr=8-2 Many thanks :) |
The OEM part number for the right side mirror glass with the piece it mounts to is: 87931-0D010
The part number is different for Japan built versus French built Yaris, so my only concern with that amazon listing would be that they don't list the actual OEM part number that it replaces.
Thanks v much, CT, that's v helpful.
Assuming I have the right part, is it as easy as just snapping the mirror on? I'm 99% sure my Yaris is French built. Thanks! |
I believe so. I think that the base for the glass has a round recess that just snaps over the white round area.
| Driver Side Axle Seal Seepage | ezhacker1 | DIY / Maintenance / Service | 4 | 05-18-2010 09:54 PM |
| LED Side Mirror from Micro Image? | IsLNdbOi | DIY / Maintenance / Service | 0 | 12-21-2009 05:08 AM |
| Driver side Seat Belt | gwasabi | DIY / Maintenance / Service | 13 | 05-09-2009 06:45 AM |
| Driver side foglight trim | gwasabi | Willing to Buy by private party | 3 | 03-03-2009 03:11 AM |
