Old 11-22-2012, 08:58 AM   #37
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
mileage already started to drop significantly. I never got back to the numbers I got last summer, so I am assuming new plugs make a difference. But I just got 80-something km's and first bar gone already. I don't even have winter tires on yet, nor snow on the ground, but the temps are dipping below 0 C now during the nights.
caper26 is offline   Reply With Quote
Old 12-03-2012, 04:32 PM   #38
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
does new plugs really help?
Old 12-03-2012, 05:52 PM   #39
Changed my plugs at ~160K kms. Didn't change my mileage at all. Was a tad disappointed.
Old 12-03-2012, 05:55 PM   #40
caineroad
caineroad's Avatar
how were the plugs looking at 160K? What plugs did u replace with?
If TB is clean, MAF is clean and plugs are good... what else could it be causing the poor mileage? I know temperature is a factor but when i bought the new car, it had very impressive mileage, now it's gone downhill.
Old 12-03-2012, 06:55 PM   #41
caper26
caper26's Avatar
Exactly. My mileage was WAY better 2 summers ago, and we had a crap summer (low temps, lots of rain). This summer past was constant sun and warm weather and my mileage was always worse than summer before.
Old 12-03-2012, 06:57 PM   #42
caineroad
caineroad's Avatar
your average from fuelly is 38mpg... and mine is 32mpg.
(US mpg)
you are doing much better than me!
Old 12-03-2012, 07:12 PM   #43
caper26
caper26's Avatar
yes, but I am comparing myself to myself. I am only asking for consistency and wondering why it has gone downhill
Old 12-03-2012, 07:13 PM   #44
caineroad
caineroad's Avatar
can you please talk to toyota and their technicians to see whats going on, and let us know the result.
thanks
Old 12-03-2012, 07:14 PM   #45
caper26
caper26's Avatar
they want to take it for a ride with a laptop connected, for a hefty price of course.
Old 12-05-2012, 07:55 PM   #46
caineroad
caineroad's Avatar
have u also tried sea foam ?
Old 12-05-2012, 08:30 PM   #47
caper26
caper26's Avatar
on a car with 20,000 K ? no I havent
Old 12-05-2012, 08:32 PM   #48
caineroad
caineroad's Avatar
Oh.. didnt know your car is so new... you barely drive this thing!!
I cleaned my MAF and TB yesterday, the car definitely feels smooth and pick up faster when i floor it. So I would assume the mpg to get better.
I also disconnected the battery for the ECU to reset for the whole night, not sure if that helps but it turned off the engine light(it was on after I cleaned the TB).
Old 12-06-2012, 04:58 PM   #49
caineroad
caineroad's Avatar
i got 64km, first bar gone.... with esso gas
but yes normally it should be over 100, maybe bad gas, try using Shell. I get the best result from them.
But i suggest trying all gas stations including smaller ones around your place, so u know which one gives the best mpg
Old 12-10-2012, 08:15 PM   #50
jayeh
Drives: '08 Yaris LB
I have an '08. I usually get about 120-160km on the first bar. 350-450 at 1/2 a tank, then 50-100 km on the bottom half a tank. It's pretty strange.
I get around the same MPG on the tank no matter how fast/slow the gauge drops.
jayeh is offline   Reply With Quote
Old 12-10-2012, 08:31 PM   #51
caineroad
caineroad's Avatar
dont lie to yourself
your average from fuelly is 423.6 km per tank.
Old 12-11-2012, 04:46 PM   #52
jayeh
I don't see what that has to do with anything?
I've had 7 tanks where I've gone over 450km.
I'm referring to the strange way the gas gauge reads not implying some strange correlation between bars used and MPG.
Old 12-14-2012, 03:14 AM   #53
caineroad
caineroad's Avatar
Just changed spark plugs, mpg still the same.
MAF and TB were cleaned, engine felt smoother and car runs faster but mpg still the same.
I think it has to do with the gas, i tend to get better mileage from Shell than Esso, and then the ethanol they put also contribute to lower mpg. A few years back there were no ethanol, and now it's 10% at most gas station. How much effect does 10% ethanol have on fuel economy, is it 10% worse? I don't think so, it could be more or less. That means the 10% ethanol (and other additives to keep them balance) can potentially affect mileage by 20%, which is just a guess. But without some scientific support, I am only guessing here.
Also gas station says up to 10%, the supplier of these fuel do they regulate the 10% enough? Do they do testing regularly to ensure the percentage?
I think it has to do with gas then. Nothing wrong with the car, everyone else is getting good mileage
Old 12-14-2012, 09:06 AM   #54
^ there is a recent thread here discussing the age old question of any benefit to using premium. In that thread, another tangent developed which discussed effects of ethanol on mpg.
The forgone conclusion is that ethanol does not have a negative effect. I had the opportunity last summer to run ethanol free gas while on vacation. My own mpg calculations showed zero difference.
