Old 12-02-2012, 05:50 PM   #163
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by TOLMACH View Post
Mine looks nothing like this inside (build quality wise) ((
Hopefully, will still do its job
It will work just fine.
The DC is a time tested design. And in my opinion, trailing edges don't matter. Those are the edges that point in the direction of the exhaust flow.
Old 12-02-2012, 06:04 PM   #164
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Tolmach yours also does not have the ceramic coating. I thought all DC headers for the yaris came coated.
Is it a replica? Poor build quality, alteration of branding, and lack of ceramic coating... sounds like a Rep.
Old 12-02-2012, 10:09 PM   #165
TOLMACH
Drives: soarer
Mine looks pretty much the same in terms of build quality and finishing as other dc headers that I see here.
I bought mine from the vendor that is listed as official dealer at DC sports web-site (LSD motorsports) - do not have reasons not to trust these guys.
Alteration of branding - kinda suspect producers of replica would do a proper replication ))
Old 12-02-2012, 11:00 PM   #166
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Tolmach, your pipes look kind of small as well but then again my Megan Racing header is 3mm larger diameter but i wouldn't think that i could tell the size difference in a picture with out side by side comparison.
Old 12-02-2012, 11:55 PM   #167
NJ Drive
Drives: 2012 Yaris SE
Can someone measure the I.D. on one of the primaries on this header? It looks similar to the OEM and somewhat smaller than the Weapon R header.
NJ Drive is offline   Reply With Quote
Old 12-03-2012, 12:18 AM   #168
TOLMACH
Drives: soarer
^ Mine measure 31 mm = 1.22 inches
Old 12-03-2012, 12:21 AM   #169
TOLMACH
Drives: soarer
Thanks.. will try to install it Tue morning.. will share my experience
Old 12-03-2012, 02:14 AM   #170
tooter
play every day
tooter's Avatar
The inside diameter of stock 2012 header runners is 28mm and the Weapon R's are 36mm...
Old 12-03-2012, 05:18 PM   #171
NJ Drive
So perhaps the Weapon R is the closest port-matched of the two considering the amount of soot on the OEM. Anyone have an I.D. of an exhaust port?
Old 12-03-2012, 05:49 PM   #172
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I measured 35mm for the port and 40mm for the gasket.
Old 12-03-2012, 06:39 PM   #173
NJ Drive
Thanks. I have to be honest- the more I gather reading about 'bolt-on' solutions, I'd rather buy one of yours, assuming you find appreciable gains. I don't doubt that you will.
I intend to run a single hi-flow with a Burns muffler anyway, so might as well do it right.
Old 12-03-2012, 08:58 PM   #174
xnamerxx
0-60 in slow
xnamerxx's Avatar
I was once told by a GM engineer that the absolute best solution and absolute worse solution for exhaust is generally only a few % different. I've taken this advice to heart knowing the expected gains and losses can only be so much.
I do expect gains but the dyno and racing will be the true test if it actually works, I have simulation numbers, but those aren't always accurate to the real world.
If you want an easy/cheap solution ots parts work, but have the same design constraints production parts have, so you won't get the "best" solution. I can tell you this I noticed a significant loss of low-mid-range torque with the DC header while getting a size-able gain in topend torque. If you look at my dynosheet you can see that the DC produces a sizeable dip between 2700-3800 rpm, it feels really gutless out of slower corners but nice up top.
Old 12-03-2012, 09:39 PM   #175
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I have to defend the DC header, as I think it's been the single best bolt-on since I started messing with this car.
First mod was a K&N typhoon intake, other than more engine noise, I didn't feel much change.
Second mod was the DC header. I noticed no mid-range torque loss and a noticeable change to the way the top end acted. The engine breathed better in the top end, instead of running out of steam before redline like before. The power across the board seems more linear. Despite the cost I would recommend the header.
Last engine mod I've done is a resonator-back obx exhaust. I didn't really notice any seat of the pants change from this.
Now with these mods the car is easier to drive. It's surprising torquey in 5th gear, I don't have to downshift to 4th gear any more when going up hills on the highway, even with passengers. It still doesn't have the top end that my Honda cars had, which it probably never will. It pulls really well in the 3000-5500 range though for a 1.5L. Overall I'm happy with the mods, I/H/E are worth it in my opinion.
4/20 NEVER FORGET is offline   Reply With Quote
Old 12-04-2012, 01:06 PM   #176
TOLMACH
Drives: soarer
Gone trying to install my header.. wish me luck ))
(First day of annual vacation.. sooo nice)
Old 12-04-2012, 01:58 PM   #177
^ Good luck, and congrats on vacation time!
Old 12-04-2012, 04:16 PM   #178
tooter
play every day
tooter's Avatar
Do show us pics of your project, and jack up the front of the car. It makes getting to the headpipe bolts sooo much easier from the bottom.
Old 12-04-2012, 05:14 PM   #179
TOLMACH
Drives: soarer
^ Thanks guys.. just finished.. took me circa 3 hours (I am kinda slow).
^Tooter: I am pretty sure you can do the whole thing without jacking a car - you just need to be a giant octopus
Will post pics and quick impressions later today.
Old 12-04-2012, 06:02 PM   #180
Golddeenoh
Golddeenoh's Avatar
^best answer ever.
