Old 03-24-2007, 04:36 PM   #1
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
Grounding kits...
ok, past all the hype....do grounding kits really do ANYTHING? Other than look pretty that is.
The theory is that the better the ground the better the engine will run ect...but can someone please explain how a better ground to the engine can result in HP gains or a better running engine?
If it really is a noticable increase I would definately install one or fab my own, it just doesnt make alot of sence to me.
Old 03-24-2007, 06:00 PM   #2
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
The theory behind the grounding wires is that it makes the whole electrical system, and thus, the ignition, more consistent, and allows for a more powerful spark- thus burning more of the fuel and air that mix in your combustion chamber.
Don't expect any huge gains, though- it's usually a 1-2% gain.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-24-2007, 06:46 PM   #3
Spades
The Hated One
Spades's Avatar
ok, got it, thanks for the help moose.
Old 03-24-2007, 09:04 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You can't feel the difference, but the logic makes sense so I'll leave mine in place.
PetersRedYaris is offline   Reply With Quote
Old 03-24-2007, 09:17 PM   #5
ChinoCharles
Drives: LB
Its a good thing to have for the price. 'Nuff said.
Old 03-24-2007, 09:45 PM   #6
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
As always,in combination with things that net small gains add up to alot,you save your pennys dont you.
And Chino is right,for the money,its a must have.
eco is offline   Reply With Quote
Old 03-24-2007, 10:37 PM   #7
joey1320
joey1320's Avatar
Drives: Yaris LB
If you absolutely have to buy one, get the cheapest one you can. please don't buy a "jdm" or blitz or whatever japanese brandname they try to sell you for 3x the price. just get the cheapo ebay kit for 20-25$.
they all do the same thing! you would be buying a sticker with the name of the "jdm" brand on it.
joey1320 is offline   Reply With Quote
Old 03-25-2007, 08:31 PM   #8
eco
eco's Avatar
TRUE DAT!!!
Old 03-26-2007, 10:27 AM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
the current has an easier flow...less resistence across the circuit. This is the FIRST thing you should do for a sound system setup. The second thing would be to put a nicer battery in the vehicle.
― Thomas Paine
Old 03-26-2007, 10:47 AM   #10
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
Got one in my car, i have to say that it's really help, but maybe it's just in your head. But i'm satisfied for the price.
But my dome light kinda blinking when the doors open. Is this normal?
jamal1984 is offline   Reply With Quote
Old 03-26-2007, 01:26 PM   #11
Spades
The Hated One
Spades's Avatar
well, I made my own yesterday. fabbed a steel bracket that connects to the nagative battery terminal. I am using 4 gauge stereo-style ground wire. I am connecting the grounds to the rear firewall next to the ECU, the starter, a ground point next to the throttlebody, the alternator bracket, and the radiator support. The cost? 0 dollars. It was made using wire I had left over from previous stereo instalations, and the bracket was made from scrapmetal I had laying around. It probbly is not as pretty as some of the grounding kits I have seen, but I blacked out the bracket and stashed it on the side of the battery housing and I hid the wires so they wont be seen.
P.S. and yes, I count my pennies, I am poor, hence why now I drive a Yaris
EDIT: I am still on the fence about it helping my engine have hotter spark, but, I figure it is good since I have a stereo system and the added grounds will help my starter and alternator last longer.
Old 03-26-2007, 02:05 PM   #12
daq421
MPG is the new cool
daq421's Avatar
Drives: 07 Yaris sedan (silver) Auto
Send a message via AIM to daq421
I'm really interested in this, who makes a good one? (grounding kit I mean..)
-Peter
daq421 is offline   Reply With Quote
Old 03-27-2007, 03:10 AM   #13
St_G
Drives: Black 2007 Yaris Liftback 1.5
Do grounding kits do anything to help with the rough idle while running the A/C? Is there anything to be done for that? It's not very pronounced, but if I could get rid of it, I'd like to.
St_G is offline   Reply With Quote
Old 03-27-2007, 01:36 PM   #14
Moose
Resident Redneck
Moose's Avatar
Not hotter, just more consistent.
My other rides:
Old 03-27-2007, 05:36 PM   #15
ChinoCharles
Drives: LB
I may just have to start whipping these up. Should the distances between grounding points in the bay be the same for the Sedan and Liftback?
Old 03-27-2007, 05:37 PM   #16
Moose
Resident Redneck
Moose's Avatar
Should be- I mean, really, a grounding point is the same no matter what kind of car it is.
My other rides:
Old 03-27-2007, 05:38 PM   #17
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
SOMEONE DO A DIY!!! please...
and will it help my 03 Corolla on that weird idling speed???
I just changed my plugs,cleaned MAF,replaced Tranny oil,flushed/replaced oil&filter with synthetic mobil1,cleaned and re-oiled the reusable filter, cleaned throttle body,ported polished and high heat painted header,raised the idle speed to 900rpm, and still it seems to go back...
Also I checked my battery,checked for engine code and alot more stuff....
THE YARIS: TINY BUT PRICEY!
BUT YOU JUST GOTTA LOVE IT....
forpinks is offline   Reply With Quote
Old 03-27-2007, 05:38 PM   #18
ChinoCharles
Drives: LB
I know, but I've been surprised by the differences in the two before. In theory it shouldn't be any different from platform to platform as long as it has the 1NZ.
Grounding kits 07WYarisRS Items for Sale by private party 55 07-28-2007 04:08 AM
HID Light Conversion Kits - $170 shipped! MobileHID Sponsors Classifieds Area 120 05-02-2007 09:04 PM
What's the difference in the Door lock Kits (wire and rod) mgthompson General Yaris / Vitz Discussion 5 03-19-2007 01:29 AM
Yaris Body Kits???? SamSam Cosmetic Modifications (Exterior/Interior) 23 01-15-2007 03:38 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
