Old 01-19-2013, 06:18 PM   #1
Prof67
Prof67's Avatar
Drives: 2009 Yaris 1.5 litre 5 door
Access from dashboard to engine compartment
My Yaris has no temperature gauge. I want to run a cable to an "outside" sensor. Any tips?
Prof67 is offline   Reply With Quote
Old 01-19-2013, 09:01 PM   #2
On the Left Hand Drive Yaris there is a giant (~3") grommet that goes through the firewall to the left of the steering column and comes out behind the battery (which is mounted to the left side, under the hood). I am not sure if the Right Hand Drive ones have the grommet in that same place on the left side, or if it moves to the right side, like the steering wheel. Put your head on the floor and shine a flashlight up along the firewall to see if you can find it.
Old 01-19-2013, 11:47 PM   #3
TOLMACH
Drives: soarer
^ I am doing the same project this coming Wed.. was thinking to drill a bunch of holes. this thread came very handy )))))
Thanks
Old 01-20-2013, 01:57 AM   #4
Prof67
Prof67's Avatar
Thank you. I have found the grommet. Can you tell me how to dismantle the dash to gain access to the grommet without drilling holes?
Old 01-20-2013, 07:32 AM   #5
Out of curiosity, which side of the car did you find it on?
I suggest going the opposite way - Instead of dismantling the dash, remove the wiper arms, cowlings, and tray to get at the engine bay side. If you are feeding something from the inside, poke through from the engine bay side, and then electrical tape the wire to the poker, by reaching up under the dash, and pull it through.
Old 01-20-2013, 10:40 PM   #6
Prof67
Prof67's Avatar
Thanks again. The grommet is to the right of the steering wheel. The battery is on LHS of car. I'll get onto that ASAP. Kind regards, Brian
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
