Old 02-01-2013, 03:03 PM   #217
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
No, but it was very close.
Yeah, it was neck in neck right down to a photo finish.
Congratulations on producing a really fine product, Garm.
Old 02-01-2013, 03:06 PM   #218
tooter
play every day
tooter's Avatar
I heard a rumor that MI was planning something like that but dont know if there is/was any truth to it
The manifold was bored for the 1zz opening and the 1nz or 1zz have the same bolt pattern so yes you can swap them
-per Jeff
I can't for someone to actually run a 1ZZ on a MI manifold and dyno it. They're a significant improvement over the 1NZ throttle body... especially in driveability. I love mine.
Old 02-01-2013, 03:10 PM   #219
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
That will be me lol I just bought the 1zz tb like a few days ago specifically to add it to this manifold. I have the big 3 bolt ons as well so I think I will be seeing really nice gains
Old 02-01-2013, 05:03 PM   #220
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
I'm excited to see this done 1.5. I was really excited to do it on mine, so I'll have to live vicariously through you on the build
Old 02-01-2013, 05:21 PM   #221
1.5
Form>Function
1.5's Avatar
lol Ill keep you updated man
Old 02-01-2013, 05:43 PM   #222
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I know there is a thread on the 1zz TB. What is the PnP part number on the 1zz TB for the Yaris with DriveByWire?
-Derrick-
Old 02-01-2013, 06:12 PM   #223
tooter
play every day
tooter's Avatar
The part number on my 1ZZ is:
22030-0D030
And the difference in throttle response is night and day...
Old 02-01-2013, 06:42 PM   #224
3cyltrbo
where do I get this throttle body without paying eleventy billion dollars?
presumably you guys (with them) are sourcing off ebay or used places?
W
3cyltrbo is offline   Reply With Quote
Old 02-01-2013, 06:46 PM   #225
tooter
play every day
tooter's Avatar
Yeah, they can get pricey. I paid the full going price for a used one on ebay that was in really superb condition.
It was $125 including shipping. They had cheaper ones but some of them look like they were underwarer salvage!
Old 02-01-2013, 06:47 PM   #226
^ That's about right for a really clean one. Dirty/worn/sketchy would be the $60-70 range.
Old 02-01-2013, 08:48 PM   #227
1.5
Form>Function
1.5's Avatar
I bought one used off a member for 55 but it needs a real good cleaning, id also like to Neo chrome it so ill be reinvesting money into it.
Old 02-01-2013, 08:57 PM   #228
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
I'm sorry if this has been asked. Is that tb a direct bolt on for our stock intake manifold?
Silver Streak is offline   Reply With Quote
Old 02-01-2013, 09:15 PM   #229
tooter
play every day
tooter's Avatar
Well, sort of... but not exactly.
A 1ZZ will bolt on because the stud holes are the same as stock at 60mm square, but the diameter of the stock O ring gasket is too small to seal the larger 55mm bore, and I don't believe that the larger butterfly when opened will clear the stock hole either.
Old 02-01-2013, 09:35 PM   #230
Silver Streak
Thanks for the info Tooter.
Old 02-01-2013, 10:37 PM   #231
3cyltrbo
I bought a sketchy looking one (will need a cleaning) for $55
quick question / do I (should I) transfer the electronics from the old to the new? (looks interchangeable?) or is it simply plug and play?
Old 02-02-2013, 12:09 AM   #232
tooter
play every day
tooter's Avatar
I switched mine just to be sure, but you could try it first with the 1ZZ chip.
But I do know this from personal experience... it will NOT work unless you chip out the epoxy and turn the allen key head idle screw counterclockwise about a turn...
It's that tiny screw just above the upper left hand throttle body stud... and don't strip it.
Old 02-02-2013, 08:09 AM   #233
1.5
Form>Function
1.5's Avatar
@tooter so the tb installation requires a larger o ring, possible chip swap, removal of epoxy, and adjusting the idle set screw? I skipped anything about the butterfly valve needing space since Im sure MI thought of those dimmensions with the new manifold design since they wanted to be able to combine the two for even better performance.
Old 02-02-2013, 11:41 AM   #234
tooter
play every day
tooter's Avatar
You're absolutely right. A larger butterfly likely won't clear a smaller stock bore, so it's a simple matter to make a larger bore and larger diameter gasket to fit both throttle bodies.
You want the flow to be compatable with the larger throttle body anyways.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
