Old 04-26-2013, 08:38 AM   #1
Ghostrd
Ghost Turd
Drives: 2008
Yaris Cattle Guard for the GhostTurd
I almost hit a coyote on the way to work last fall and thought to myself, "Boy, this would spell doomsday for the GhostTurd."
I did this with the following tools: Drill, welder, chopsaw, angle grinder, plasma cutter (although you could get by with other), and of course, paint.
It is very solid, supported at 4 points. I'm new to this site but have done several fun modifications to the car to make it more comfortable and safe to drive.
If there is a lot of interest in the cattle guard, I can post some more pictures and explanations.
Ghostrd is offline   Reply With Quote
Old 04-26-2013, 09:02 AM   #2
BT91
BT91's Avatar
Drives: 2008 Yaris Sedan
Curious to see how it turned out. Post some pics
Droppin Gears
BT91 is offline   Reply With Quote
Old 04-26-2013, 09:58 AM   #3
Definitely post pics. There has been quite a bit of interest on doing something like that.
Old 04-26-2013, 10:02 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Where were the first pictures? Im so angry right now!
-Derrick-
Old 04-26-2013, 10:37 AM   #5
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
of course... post some pics!
B2FiNiTY is offline   Reply With Quote
Old 04-26-2013, 03:29 PM   #6
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
I hit one of those damn things in my Yaris. It broke the lower grill and cracked the bumper cover below the lower grill. I also had to replace a handful of those little push-pin retainers.
It was a lot less damage than I expected. I was running 60mph at the time.
Old 04-27-2013, 12:46 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
I hit a giant jack rabbit, this would have saved me...
Old 04-28-2013, 09:53 AM   #8
Ghostrd
Ghost Turd
Drives: 2008
I'd posted this in the tech section but thought it could benefit someone here. I nearly hit a coyote one morning with the Ghost Turd so this was the solution. It took about 45 hours start-to-finish and is very solid.
Old 04-28-2013, 09:58 AM   #9
Ghostrd
Ghost Turd
Drives: 2008
OK, pics.... How do you upload pictures when the 'Insert Image' icon wants you to point to a URL? (help...)
Old 04-28-2013, 11:08 AM   #10
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
You can either upload to a file hosting site like Photobucket or there should be an another option to add the pic as an attachment to the thread in the "advanced" menu.
I use photobucket...
-Type 07 FFL-
My odometer 03/11
Old 04-28-2013, 11:11 AM   #11
mazilla
advocatus diaboli
mazilla's Avatar
NM, I see you figured out how to post pics. That is intense...
-Type 07 FFL-
My odometer 03/11
Old 04-28-2013, 02:57 PM   #12
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Now put some big round foglights in the cattle guard and make it look like a rally car.
Black_griffin6 is offline   Reply With Quote
Old 04-28-2013, 05:13 PM   #13
Ghostrd
Ghost Turd
Drives: 2008
More pictures of the GhostTurd cattle guard
All of the bends are done with a chopsaw, welder & angle grinder. Tedious.
The trickiest part is building your grommet mounts. You have to buy slightly longer metric bolts with which to replace the bumper mounting bolts because your grommets (what you see sticking out of the plastic bumper cover) have a 1/4" base that require more bolt shank. I just used a generic holesaw & drill to get the 2nd bumper hole made (the driver side). The passenger hole is already there for your tow hookup.
If someone is really serious about building one, I can put the car back on the rack and take some pictures of the underside for the lower supports. Without solid under-support, this would only be for decoration.
Old 04-28-2013, 06:02 PM   #14
MadMax
MadMax's Avatar
I gotta say, that's different!
Old 04-28-2013, 06:25 PM   #15
mr_miles
Drives: 2013 Yaris
Wow. That thing is intense.
Old 04-28-2013, 08:09 PM   #16
ilikerice
ilikerice's Avatar
I think I will be the first yaris in destruction derby with this setup... challenge accepted
-Derrick-
Old 04-28-2013, 09:05 PM   #17
I am very impressed with the fabrication technique for achieving the bend. Some serious work went into that.
Old 04-28-2013, 09:09 PM   #18
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've contemplated this once or twice, but I'm not sure how I'd go about anchoring the lower portion of it. I think I would go with mandrel bent round tubing attached to square/rectangular uprights, like on a police cruiser. Since I'm not skilled with a welder and don't have a mandrel bender, it's just going to be a pipe dream for me.
That, and there's probably some interference with pedestrian crash safety regulations. =(
Tags
brush, brush guard, bumper, cattle, cattle guard, deer, grill, guard
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
