![]() Drives: 08 3dr LB Join Date: Feb 2013
08 cup holder removal?
I want to remove the cup holder "door" so I can clean all the previous owners coffemate out? I have the manual on disk, but it states only how to do it when removing dash? Does the door come off without removing glove boxes?
Also in the manual pic it is not clear if you pry out on the hinge or in? Any thoughts? |
Open the holder there is a screw down in the bottom remove that, then you will have to pry the sides out from the dashboard pulling forward. It does take a good amount of force but it will come out.
#3 | |
Do you pry out on arms? |
yes i would try with fingers first or a plastic trim removal tool.
#5 | |
(and other members as well).
Gross?
Then. They wouldn't want to see what I found under the seat, when I took them out
Ok! On a serious note. I have replaced the water pump, installed cruise control. But I cant get the @&$&@& cup holder out. Anymore force, and I will rip the dash out! It can't be this hard? How about it scott! Any thoughts?
I believe I would rather take the motor apart than try and get this @!$$& cup holder out! |
#8 | |
Thanks scott! That's what I wanted, didn't want to hear. So Q tips will have to do for now!
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Windex, a used toothbrush and a vacuum. Please don't use your current toothbrush.
| CUP HOLDER REMOVAL? | SweetRS | Cosmetic Modifications (Exterior/Interior) | 13 | 09-19-2016 09:43 AM |
| Loose Change holder(?) and cup holder | nemobile | Cosmetic Modifications (Exterior/Interior) | 14 | 02-21-2012 10:56 PM |
| Dash Cup Holder | dzcab | Cosmetic Modifications (Exterior/Interior) | 5 | 08-17-2011 11:24 PM |
| cup holder removal | DOMAV | General Yaris / Vitz Discussion | 9 | 08-27-2009 12:32 PM |
