Old 12-21-2011, 07:59 PM   #145
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
The hood pins ground when the hood is open, so you leave them floating (i.e. not connected) to bypass.
Alright well that eliminates that.
I'm going to verify my ground point ... that's the only other thing I can think of.
devinlamothe is offline   Reply With Quote
Old 12-21-2011, 08:17 PM   #146
Unplug the power connector from the remote starter and measure the voltage between the ground pin and the constant power pins. That will verify exactly what the unit is getting.
Old 12-22-2011, 03:27 PM   #147
devinlamothe
OK ground is fine. I was able to get the shutdown code and it says "Transmitter shutdown (or push button)" (the LED on the unit flashes 4 times).
Car isn't even attempting to crank at all and remote errors out. I really wish these car starters had an LCD display, lol
Old 12-22-2011, 03:41 PM   #148
So that means that it thinks that you are either hitting the button on the remote a second time to kill it, or the valet mode is activated. Go through the procedure to turn valet mode off.
Old 01-23-2012, 11:19 PM   #149
yarisyeti
Drives: 2011 Yaris 3d LB
Is it better to solder or tap into the wires?
Does either void the warranty?
Thanks!
yarisyeti is offline   Reply With Quote
Old 01-23-2012, 11:24 PM   #150
Thanks!
Nothing voids the warranty unless what you do leads to failure of it or something else.
Soldering typically is better, but wire taps work fine and can be a bit safer to work with under the dash. I have used wire taps on the last 4 of my cars that I installed remote starters on and have driven 100K+ without an single issue.
Old 01-24-2012, 12:13 AM   #151
yarisyeti
Next question. I am adding electric windows to my bone stock yaris. I am using a Prestige APS787C and it says it can roll windows up and down.
On this site: http://voxrightnow.custhelp.com/app/...e-start-system It says I can use channel 4 and 5 to do this, my question is, can I just hook the wires for channel 4 and 5 to the power and ground of the window, or do I need to hook up relays?
If I have to hook up relays, how will I wire them?
Here is my install manual as well! http://www.clubgpstore.com/art/aps787_IM.pdf
Thanks a million!!
do i use this relay:http://www.automotiverewire.com/Nava...ayswindows.htm
Old 01-24-2012, 07:07 AM   #152
Thanks a million!!
For the remote window closure you need an auto window closer device, like the DEI 530T. The aux output of the remote starter would become an input to the 530T to tell it to crank up the windows (or with another output, down as well for airing it out in the hot weather).
Old 01-24-2012, 01:48 PM   #153
yarisyeti
could I use a 529T?
Old 01-24-2012, 01:49 PM   #154
yarisyeti
Can I use a 529T?
Old 01-24-2012, 02:15 PM   #155
Can I use a 529T?
Yes. The 529T just gives you one direction, whereas the 530T gives you both.
Old 01-25-2012, 01:07 PM   #156
yarisyeti
wouldn't hooking up a relay like thishttp://www.automotiverewire.com/Navagation/spdtrelayswindows.htm work just the same?
Old 01-25-2012, 01:17 PM   #157
Yes, although the relays will stay energized as long as the output channel is on, whereas the 529T or 530T has some intelligence to turn its relays off. The problem with leaving them energized is that if you trigger the output channel after turning the car off, and then leave the car parked for a day or so, you may come back to a dead battery.
Old 01-24-2013, 10:36 AM   #158
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
@ CTScott - Thanks for sharing all this information with other Yaris owners.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 02-08-2013, 06:53 AM   #159
Originally Posted by pat005 View Post
Sorry to be "that guy" but I seem to be struggling with something I feel isn't very complicated but don't want to mess it up. Here's mine but I can't find from the DIY I can't seem to find anything that looks remotely similar with the two black and two pick wires. Oh yeah, 2008 HB Yaris. Thanks
https://plus.google.com/photos/11558...66988681874529
Link to the two photos
You are about a foot to the left of where that connector in my picture is. It is the ignition switch connector, which is located at the base of the ignition switch, on the right side of the steering column.
Old 07-20-2013, 06:52 PM   #160
WestCoast
Drives: yaris
Thank you so much CTScott,
My 2007 auto transmission Yaris is a 5 door hatch back without keyless entry, manual windows, but have a button to lock and unlock the door. Does it need a keypass or not?
Thank you again,
WestCoast is offline   Reply With Quote
Old 07-20-2013, 08:56 PM   #161
Thank you again,
Most likely not with an 07, but you can tell by looking at the ignition switch. If it is all metal then no, if the part that rotates is metal and the part that surrounds it is black plastic, then yes.
Old 07-21-2013, 02:53 AM   #162
WestCoast
Drives: yaris
Thank you so much for your reply so quickly. My ignition switch doesn't have the black plastic surround it. So should be don't need the keypass.
My remote starter is Firstech CM6200. I connected the CN1(Accessory, Starter, Ignition, Ground, Constant 12V, 12 Parklning light output), and CN4(Unlock Output, Lock Output).
But didn't connect the CN2, which are (Output to Starter-kill), Hood Pin Input, .... etc.)
Because I don't know where to find these cables in your diy chart. Any advices for me?
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
