Old 01-24-2013, 05:53 PM   #73
Originally Posted by jelo View Post
Just picked up my 2013 Yaris - will want to do this down the road, so it is time to ask: Anybody know the differences between 2012 and 2013 for cruise control install?
No difference at all.
Old 01-25-2013, 07:56 PM   #74
jelo
Drives: 2013 Yaris L
Great - Thanks!
jelo is offline   Reply With Quote
Old 01-30-2013, 06:29 PM   #75
ksejrs
Drives: 2012 Yaris LE
Awesome pictures made for an easy install!
Thank you CTScott, richard rsp & 12BusYaris,
I just recently bought my second Yaris(2012). My daughter took the first one (2009) to college. I was disappointed that it didn't have cruise control seeing as it had all the other power options. I was thrilled when I found this site and learned how easy it was to remedy. I bought the stalk online for about $58 with shipping and it took about 30 minutes tops to install. Just need to cut the hole in the cover piece. Anyone have measurements for that? Thanks again!
ksejrs is offline   Reply With Quote
Old 01-30-2013, 07:16 PM   #76
I still haven't had a chance to get my hands on a 2012 to take the measurements. I actually have a batch of the 2012+ cover pieces on order, and should have them in hand next week.
Also, with the cruise control stalks and the clutch switches, I always have some on hand and sell them for a fraction of retail.
Old 03-19-2013, 09:20 PM   #77
dennismr
CC Stalk install on my 2013 Yaris L Automatic
Got my CC stalk from CTScott 2 weeks ago, but a family emergency kept me from installing it until now.
Got home from work just before 7pm tonight, parked in the garage and popped the hood of my 2013 Yaris L automatic in Absolutely Red so I could disconnect the negative terminal of the battery before I removed the air bag from the steering wheel. Went upstairs, changed my clothes, and started the install...
Parked with the steering wheel upside to make removing the airbag easier.
Removed the lower#2 steering wheel cover (on side of steering wheel), and then pushed in the 3 pins that hold the airbag, as described in other threads, and the airbag pops off very easily. Took a couple of minutes to find the pins, but easy once I did find it.
Located the horn wire, and removed it. Placed it aside, as it won't be needed anymore.
Pulled the CC stalk out of the box that it was mailed in
Slide it into where the lower#2 steering wheel cover was removed, and screw the 2 screws in to hold it in place.
Plug the 2 connectors attached to the stalk into the same connectors that I earlier removed the horn wire from.
The airbag just pushes back on and clicks into place, and the CC stalk is where it should be...
Reconnected the battery, turned the ignition on, turned the CC on, and the dash light turns on just like it should.
Took it for a short drive, and everything works exactly like it should. The best $40 investment in this great little car I could make!
The whole process took me from 7:04 pm until 7:25, and that included talking to my neighbor for 5 minutes when he got home from work.
Thanks CTScott and yarisworld!!!
dennismr is offline   Reply With Quote
Old 03-19-2013, 09:55 PM   #78
^Nice!
By the way, I recently acquired a batch of the replacement covers for the side of the 2012-2013 steering wheel, which have the hole for the cruise control stalk. They are $5 shipped in the US.
Old 04-12-2013, 03:09 PM   #79
misterwolfe
What is a clutch?
Drives: 2007 Yaris HB
Send a message via AIM to misterwolfe
Can I do this to a 2007 Yaris Liftback with the power option added? I have everything but cruise.
misterwolfe is offline   Reply With Quote
Old 04-12-2013, 03:18 PM   #80
Yes. Below is a link to my DIY for 06-11 Yaris. I carry all of the part required if you are interested in installing it:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 04-12-2013, 03:21 PM   #81
misterwolfe
What is a clutch?
Thank you! Though with requiring to wire up my steering column, that may be my roadblock. Will look into this. (I am colorblind, and at the mercy of my father doing these for me.)
If it is relatively easy, I'll totally buy an entire kit from ya. Also, hoping for keyless entry soon too!
Old 04-30-2013, 09:55 PM   #82
Licky
Drives: yaris
Hi everyone, I am new here, and from australia.
I have a Yaris YR 5 door (base model, 1.3 manual)
I have "acquired" a OEM cruise control stalk and cable, I can fit it into the steering wheel no worries, the cruise light comes on, though can not set the speed. Would this be because of the clutch switch?. I have tried Toyota, and they werent really much help. Though they did come back with a $90 part. I do have to push the clutch in to start the vehicle to begin with though, so i would assume it would already have one?.
Could someone please shed some light for me?
THanks.
Licky is offline   Reply With Quote
Old 04-30-2013, 10:09 PM   #83
THanks.
There are two clutch switches on a manual transmission Yaris. The pre-installed on is the push the clutch to the floor to start the car one. The one you have to add for cruise control works the opposite way. It replaces the stopper bolt that the clutch arm rests against (when your foot is not on it) and it signals the ECM when you barely touch the clutch pedal (to prevent the revving that would occur if the clutch was pressed when cruise was applying throttle).
Old 07-05-2013, 09:09 AM   #84
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
wiring diagrams
[QUOTE=CTScott;615019]I recently obtained the wiring diagrams for the 2012 Yaris. Much of the wiring and connectors remain the same as the second generation Yaris. This is the case for cruise control, so 2012 Yaris owners can DIY cruise control using the same OEM stalk.
For the 2012 the wiring is the same as that of the 2009-2011 Yaris, where the wiring from the ECM to the steering column is (theoretically) there. Also, the 2012 Yaris has the cruise control "On" and "Set" indicators built into the instrument cluster.
CTScott Hello, if you have wiring diagrams for the 2012 Yaris, you help us and us with them? Please much.
geoded is offline   Reply With Quote
Old 07-06-2013, 05:46 AM   #85
geoded
geoded's Avatar
Which is code oem cruise control stalk for Toyota Yaris ?
Old 07-06-2013, 09:56 AM   #86
geoded
geoded's Avatar
Code for cruise control stalk toyota yaris is 84632-34011 or 84632-0F010, can you help me ?
Old 07-06-2013, 03:06 PM   #87
geoded
geoded's Avatar
anyone can help me?
Old 07-31-2013, 06:48 AM   #88
geoded
geoded's Avatar
Hello everyone. I bought the pieces of picture 1, I installed according to picture 2 3.4, but the result was negative, to me does not work. I 1ND-TV engine, 1.4 D4D 66kW respectively. Can someone help me? You need to do something else than I did? Have to change terminals 1 and 2 of the 4-pin connector in the 10 pin?
Old 07-31-2013, 07:50 AM   #89
You have everything installed in the proper place, but according to the wiring diagrams the 1ND-TV Yaris does not support cruise control.
Check the connector on the other end of the spiral cable, which is located under the cover for the lower part of the steering column. The question is if the two wires are present there that would connect to the cruise control stalk wires under the airbag.
Old 07-31-2013, 08:33 AM   #90
geoded
geoded's Avatar
I understand the need to loosen the screw from the one in picture 1 and picture 2, but do not know exactly what wires need to see, you have a picture of what should I see there?
cruise control. 2012
