Old 08-16-2013, 10:18 PM   #253
andulong
andulong's Avatar
Drives: 2008 Hatch Red
Thanks CTScott, I think I will swap them out tomorrow then. Not sure I can do the seam sealing that is mentioned but at least the new bolts should add a few more years until something breaks.
andulong is offline   Reply With Quote
Old 08-24-2013, 12:57 AM   #254
camh
Drives: 2008 Toyota Yaris
2008 Toyota Yaris sedan 34,500 on May 10, 2013 After full routine maintenance at my Toyota dealer (tires rotated, oil change, inspect ball joints, drive shaft, nuts, bolts, fluids, road test vehicle) on my daughter's car, we left to go to my son's graduation in Mass. about 3.5 hour drive. Fifty miles into the trip at 65 mph (I was driving, 35 yrs experience, no accidents) hot weather, dry roads, around noon lots of cars, three lane highway, we were in the slow lane following traffic, her car goes into a skid. I had no idea what was happening other than trying to avoid hitting other cars, going off a steep drop to the right or trying not to hit the cement median. I've been in skids before on bad winter roads but not at 65 mph. My foot was off the gas and I was not breaking, trying to regain control of the car. After trying to regain control after the 3rd skid the car took us into 180 degree spin and as we headed into the cement median I slammed on the brakes. I have since found my "Warranty Enhancement Notice" on her vehicle. The letter's not dated, I don't remember when it came but I had filed it in with her car info. I did not remember this letter but a month before the accident I would hear a clank noise if I went over a dip or if I turned her steering wheel sharply to the right when parking. She's away at college so I only drive her car every other day locally and back and forth on college pick ups. Our lives were spared that day and we did not hit anyone else. I would have to say it was a miracle. PLEASE if you have a Yaris 2006 - 2011 do not wait until it starts to make noise before you get it checked. I would have it checked every 6 months. Once this bolt breaks off, it is too late.
camh is offline   Reply With Quote
Old 08-24-2013, 11:00 AM   #255
Hershey
Glad to see everyone is o.k. , imagine nerves were frayed . We have these noises and can't get any Toyota service center to replace the bolts . They never hear it and appears to be fine on the lift . We also got the notice . Should make it mandatory .
Old 08-24-2013, 11:34 AM   #256
camh
After doing alot of searching online, I have found two lawsuits for wrongful death regarding the Toyota Yaris 2008. One was a soldier home and the other a college student. If my daughter and I had been killed that day they would have wrongly assumed it was our fault, when in fact it was the control arm. There are several others who documented online their accidents at a lower speed. You are 100% correct it needs to be a mandatory recall. If this got media attention perhaps then it would be taken seriously.
Old 08-24-2013, 07:44 PM   #257
bronsin
bronsin's Avatar
My BMW F650 motorcycle stalled at lights. One a year at first then after three years every week. BMW had it three times and couldnt fix it. Other bikes did it too.
No recall ever issued. Probably moot because I doubt they could have done naything anyway. : (.
Old 08-24-2013, 10:39 PM   #258
Hershey
Went and got the bolts replaced . No appointment , just popped in with the notice from Toyota . The previous 2 did nothing . 2 new bolts , but it still creaked when pulling onto the uneven surface of a restaurant parking lot . Should we be concerned of that ? Here's the invoice .
Old 08-24-2013, 11:04 PM   #259
Hershey
90119-14126 (They are about $4 each)
Torque is: 118 ft lbs.
The part # stated on the invoice is 90119-14151 . Is this the new part number or is the bolt / washer part # for the sedan control arm different than that of the hatchback ?
Old 08-24-2013, 11:50 PM   #260
90119-14151 is a new part number. It replaces 90119-14126 and 90119-14144.
Old 08-24-2013, 11:54 PM   #261
Hershey
CT , thanks for the quick response . Should it still be creaking ? Wouldn't think so . .
Old 08-24-2013, 11:56 PM   #262
The creaking probably has nothing to do with this bolt. It is more likely the bushing around the horizontal bolt that is creaking.
Old 08-25-2013, 12:10 AM   #263
Hershey
Horizontal bolt of the front strut ? If so , should that be covered under the PLATINUM extended warranty ? Really appreciate your help.
Old 08-25-2013, 06:34 AM   #264
No. The horizontal bolt that allows the A-Arm to pivot up and down.
Old 08-25-2013, 12:13 PM   #265
Hershey
How long of a job is it to be replaced and can it be dangerous to drive? We found that uneven outer tire wear is one of the symptoms which we have on both front sides. 7/32s on outer sides of both front tires and the rest is 8/32s . The Bridgestone Ecopia EP 422s' started at 11/32s and were installed on 4/6/13 . They've been rotated once . Seems like quick wear . The previous tires wore quick too . Those were Continental Pro Contact Eco Plus . Don't drive like a speed demon , just average .
Old 08-25-2013, 12:28 PM   #266
Hershey
Does anyone have the clunking of the front end after the 2 bolts were replaced ?
Old 08-25-2013, 07:51 PM   #267
Hershey
Another thought . Will the sedan need an alignment if the front suspension is repaired ? Would think so .
Old 08-25-2013, 09:19 PM   #268
Not if just the bolts are replaced. If the full service is done where they drop the A arms and seal the seams, then alignment should be done.
As another thing to worry about, today I was finishing my disassembly of the Yaris I am parting out. The front bolts were perfect (this is a 2007 California car that appears to have never even made contact with water with how perfect all metal parts have been).
When I dropped the rear axle beam I noticed that one of the bolts that mounts it to the body had a significant spot of corrosion. This was the only bolt on the entire car that had a hint of rust. This makes we want to take a peek at the ones off my Yaris which have seen lots of Winter salt.
In this picture the long ones on the left are the rear beam bolts and the right ones are the A Arm bolts:
Old 08-26-2013, 07:06 PM   #269
NEexpat
Drives: 2009, auto, 4dr LB
^ I'd be interested to know what you discover on your cars Scott.
That spot high up on the thread like that, not good, very odd considering the condition of the rest of the car.
Perhaps just a bad bolt.................................or is there some sort of design flaw with the rear axle beam like with the A arms, great now I'm going to go slide under my car and look about.
NEexpat is offline   Reply With Quote
Old 08-26-2013, 08:54 PM   #270
bronsin
bronsin's Avatar
You know I just want to express appreciation for this site which keeps us so well informed about the (relatively minor) problems with our cars. My hat is off to you all!
Also my thanks to Toyota for making the Yaris the quality, practical car that it is. You should read some of the problems cars on other sites are having!
And REALLY read the problems BMW motorcycles are having at The Chain Gang.com!
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
