Old 10-01-2013, 09:37 PM   #1
Fidelio
EcoFriendly
Fidelio's Avatar
Drives: 2007 Vitz HB
Help: Troubleshoot Windshield Wiper Motor
Hi -
YR: 2007
Model: HB
Ive checked and replaced the fuses for the front windshield wiper but it's still not working. I can spray water through the hood jets but thats about it.
Could it be the relay or motor?
What are the chances of being the motor?
I am guessing spending $12 would be cheaper than 112 for the motor.
Any ideas?
Fidelio is offline   Reply With Quote
Old 10-01-2013, 10:42 PM   #2
The 25 A WIP fuse feeds the wiper stalk, which has the relay contained within it.
Did you perchance have the wiper cowl off recently, where you might have forgotten to plug the wiper motor connector back in?
If not, try jumping the black wire on the wiper stalk connector to the light blue wire next to it and the wiper should run while those two wires are jumped.
If you end up needing parts, I have both a wiper stalk and a wiper motor on hand.
Old 10-01-2013, 11:00 PM   #3
Fidelio
EcoFriendly
Fidelio's Avatar
awesome. Ill check. I only checked the fuses and made sure it was blown. To get to the motor just remove the blade arms and panel?
Old 10-01-2013, 11:14 PM   #4
Correct.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
Hose for windshield wiper broke HDS DIY / Maintenance / Service 1 04-06-2012 11:26 AM
Passenger side windshield wiper daf62757 General Yaris / Vitz Discussion 1 12-23-2011 06:12 PM
Rear Wiper Motor 49erRider DIY / Maintenance / Service 5 06-07-2011 12:12 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
