Old 10-27-2013, 06:54 AM   #1
OhSevenOhSix
Drives: 2008 Sedan
'08 Cruise control not working
First time poster, be gentle please
I have an australian '08 model Yaris, and have just tried to install a Rostra cruise control, unfortunately it does not seem to want to work.
After some research I quickly found that it was not possible to do the easy install on the australian model of Yaris, by just adding the control stalk. I took the chance on the ECM etc being roughly the same on the '07 and '08 models and bought a Rostra 250-1873 kit to fit an '06-'07 Yaris.
The install went smoothly with the wiring and connectors being the exactly the same as supplied, and pictured in the documentation.
Took it for a test drive, light comes on, but acc/decel does not work.
Anybody got an idea whether the 06-07 Rostra CC should work on the '08 model car? Are there any known differences between the ECM's on the 06/07 and 08 cars? Any other advice (constructive) will be appreciated.
TIA
Regards, Graeme
OhSevenOhSix is offline   Reply With Quote
Old 10-27-2013, 09:20 AM   #2
The Rostra kits are harder to diagnose than the OEM cruise control is. I would start with the VSS (vehicle speed sensor) connection, making sure that is is properly crimped on the wire and making a good connection.
Old 10-28-2013, 07:42 AM   #3
OhSevenOhSix
Drives: 2008 Sedan
Thanks so much for the reply, and indication of what to look at.
Will get in and check that out as soon as I can get to it.
Just for clarification. Can you see any particular reason why the '07 model CC unit will not work in an '08 model car?
Old 10-28-2013, 08:21 AM   #4
No. The 250-1873 kit would actually work on 06-11 AUS market Yaris.
Old 02-12-2019, 02:07 AM   #5
dineshkck
Drives: Toyota Yaris 2007 NCP90R
Hi Guys,
I bought the same 250 1873 for my Yaris 2007 3DR hatch and i have the same issue. The led comes up but it doesn't keep the speed for some reason. I even did all; troubleshooting provided by rostra in the guide and all comes okay.
Any advice ?
@OhSevenOhSix Did your started working ?
dineshkck is offline   Reply With Quote
cruise control, electrical, yaris 2008
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
