Old 11-12-2013, 11:14 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
'09 5-door LB w/ Tanabe NF210 springs. Need new tires.
So I have Tanabe NF210 springs on my '09 5-door LB. All these years, I've had Bridgestone Potenza tires (RE92 - P185/60R15).
It's time for new tires and I'm looking at Bridgestone Ecopia EP44 tires that are P185/65R15.
Will I have any issues with these Bridgestone Ecopias?
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 11-13-2013, 07:04 AM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
WIth stock wheels and no spacers I doubt you will ever run into rubbing issues
Old 11-13-2013, 09:49 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Ok, in addition to the Tanabe NF210's I also have MB Drifter wheels. I believe they're 15".
MB Drifter 15"
http://www.discounttiredirect.com/di...=Car%2FMinivan
Tanabe NF210
http://www.tanabe-usa.com/nf210.asp?id=2
Heatware:
Old 11-13-2013, 03:40 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
i'd go 205/55R15 with 15x7 wheels..
Old 11-13-2013, 03:51 PM   #5
1.5
Form>Function
1.5's Avatar
If you arnt rubbing now going from 60 to 65 should not make much of a different.
185/60 = 111mm profile
185/65 = 120.25mm profile
thats only a 9.25mm difference which is just about 3/8".
Im assuming your wheels/tires are not flush to your fenders at 7" +40 so any change in height should not be noticed much. When you hit big bumps does the tire touch the top of the wheel well? That may be the only thing that could change and i even doubt that.
Old 11-13-2013, 04:22 PM   #6
IsLNdbOi
IsLNdbOi's Avatar
I ended up going with Kumho EcoWing KH30s. The Kumhos are P185/65R15 86H BW.. Not sure if the sound I hear on some bumps are the wheels hitting the wheel wells or if they're the Tanabe springs.
Heatware:
Old 11-14-2013, 08:49 AM   #7
IllusionX
That's really interesting, since you are stretching..
http://www.willtheyfit.com/index.php...et2=40#content
Old 11-14-2013, 12:31 PM   #8
IsLNdbOi
IsLNdbOi's Avatar
What is "stretching"?
Heatware:
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
KSPORT GT vs. Tanabe DF210 Lowering Springs bad_bwoy007 General Yaris / Vitz Discussion 1 04-12-2011 01:01 PM
slightly used set of tanabe nf210 springs($120 OBO) marlondog Items for Sale by private party 3 07-08-2009 08:31 AM
FS: Tanabe Front Strut Bar + Springs BNIB junktea1 Items for Sale by private party 11 04-30-2009 09:04 PM
WTT: Tanabe DF210 4 NF210 or Similar bdc87 Items for Sale by private party 0 11-06-2008 05:40 PM
