![]() Drives: Yaris Sedan '07 Join Date: Aug 2009
14mm replacement bolt on alternator?
Greetings,
Made the attempt to replace my timing belt today, but had a dickens of a time trying to get the lower 14mm bolt to come loose! Managed to round the bolt head in the process... Left the setup as is and began a search for the replacement 14mm bolt... sadly I cannot seem to find a resource for this part! any help? |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
There's no timing belt on our Yaris. It is chain driven.
I think you may be referring to our drive belt. The bolt you speak of sir is the alternator lower bolt? It is a bit of a pain to remove. What you need is a extension on your small ratchet. Use a pipe on your 1/4 drive ratchet or maybe a small torque wrench would work. And push ( anti clockwise) directions. You can purchase the bolt at your local toyota dealer. |
I should of searched a bit more before posting, found the part code!
90105-10075 And yes, drive belt!
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
new bolt
when u put the new bolt in put a little anti-seize lube on the threads for easy removal the next time you need to adjust or replace the serpentine belt. a swivel ratchet with a long handle works pretty good too.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
| Alternator replacement on 2007 Yaris | Slipangle | DIY / Maintenance / Service | 4 | 07-10-2012 10:38 AM |
| 2 bolt alternator, lower pivot bolt | jstantherprsn | DIY / Maintenance / Service | 7 | 04-12-2011 10:02 AM |
| bottom long bolt for alternator | yaris9876 | DIY / Maintenance / Service | 5 | 05-24-2010 02:02 PM |
