Old 02-01-2014, 10:57 AM   #1
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
No stereo at all won't even turn on
I was trying to get my amp out of protection mode and now my stereo in my car won't even turn on ? What the hell ? I disconnected everything from the amp but I get nothing ? Help
400 dollar yaris is offline   Reply With Quote
Old 02-01-2014, 11:00 AM   #2
400 dollar yaris
Anyone know what fuse for the car stereo ?
Old 02-01-2014, 11:48 AM   #3
400 dollar yaris
i think it may be a blown fuse. im trying to figure out why the amp wouldnt come out of protection mode. before it blew the fuse by my dumbass accidentally touching the wires together, it was working fine until the past few days had been really cold. then it went into protection mode which started causing problems and no output.
Old 02-01-2014, 12:29 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Fuse cover under dash has a diagram on it and lists fuses. Also if you have an aftermarket headunit check fuse on that as well.
How you testing fuses ?
Old 02-01-2014, 03:19 PM   #5
400 dollar yaris
I replaced the fuse and tested all wires with a light and they all have power the ground doesn't make the light come on does that mean I have a bad ground ?
Old 02-01-2014, 04:05 PM   #6
400 dollar yaris
i have removed everything from the amp except for the ground power and remote wire. it is still in protection mode so i brought the amp inside to have it warm up. can it be too cold for the amp to work? i know that they can overheat but idk if the amp can freeze. im about to check the wires on the subwoofer itself, but if that is ok i dont know what could be causing the amp to be in protection mode.
Old 02-01-2014, 05:16 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Crossed speaker wire , loose or touching is oje possibility for amp to go protect mode as for deck if after market it will have its own fuse on the back ...like 10amp
Old 02-01-2014, 06:28 PM   #8
400 dollar yaris
im using the stock head unit and i made sure non of the speaker wires are touching
Old 02-01-2014, 08:02 PM   #9
_S7V7N_
_S7V7N_'s Avatar
Does your radio turn on ?
Old 02-01-2014, 10:13 PM   #10
400 dollar yaris
Yes it does turn on . There is just no output to the speaker because the amp is in protection mode.
Old 02-01-2014, 10:57 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
http://www.bcae1.com/repairbasicsfor...pinprotect.htm
found this hope it helps
Old 02-01-2014, 11:39 PM   #12
_S7V7N_
_S7V7N_'s Avatar
How are you running Rca's to amp ?
What brand amp ?
Old 02-02-2014, 12:52 PM   #13
400 dollar yaris
i have a lanzar vector 1000 watt amp VCT-2110 I have a line out converter connected to the back speakers and the RCA wires running from that to the amp. the thing is it was working perfectly until it got really cold here. then it went into protection mode for no reason. i didnt touch my set up at all that has been working perfectly for well over a year.
Old 02-02-2014, 01:08 PM   #14
_S7V7N_
_S7V7N_'s Avatar
Install amp in somebody elses car then. If it still protects time for a new one.
Replacing the stock stereo in a Yaris 2, #2039; 56k, are you serious? Kar98 In Car Entertainment + Electronics (audio / video / alarm) 6 10-02-2017 04:18 AM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 12:39 PM
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 03:41 PM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 07:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-29-2009 12:53 AM
