Old 02-06-2014, 08:03 AM   #1
tkhtx1
Drives: toyota yaris 2009 robotic 100
yaris wont start
hi,
I bought toyota yaris 2009 100 model few months ago, cost me 18.5k $ (everything is so expensive in Israel, even used cars :().
anyway after few weeks I started having problem starting the car.
the breaks will simply lock and become hard to push, the car will be on neutral but it wont start.
then I found out that moving the gear to "R" and back to "N" fixed the problem.
I wen to toyota garage and they told me that the battery is probably bad. so I paid for new one.
but the problem continues.
every time I started the car it only get worse.
If at first I had to move to "R" to start the car, after few weeks I had to wait and play with the gear some time I waited 10 minutes in the car until it started.
now the car simply wont start at all.
in the garage the simply don't know whats the problem is, the car is still there...
It makes me really sad because I really like the car.
I can do over 800km per tank.
anyway does someone know whats wrong with the car?
I can see on the monitor that playing with the gear actually changes the status from "R" to "N", so I guess that it works...
tkhtx1 is offline   Reply With Quote
Old 02-06-2014, 08:48 AM   #2
bronsin
bronsin's Avatar
No check engine light?
Old 02-06-2014, 09:05 AM   #3
It sounds like the park/neutral switch on the automatic transmission is acting up. Another person on here recently had a similar issue and rather than paying >$200 for the replacement part, he disassembled the switch assembly (the grey block on the transmission where the shift cable attaches to) and found that it had some internal corrosion. He cleaned the contacts, reassembled it and it was then fine.
Old 02-06-2014, 03:20 PM   #4
tkhtx1
thank you I will check it out.
About the check light engine, its fine...
Old 02-11-2014, 11:08 AM   #5
tkhtx1
Turn out that it was just a minor sensor problem. the sensor that indicate that the gear is on neutral did not worked.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 12:39 PM
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 07:14 PM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 12:53 PM
