Old 02-08-2014, 10:55 AM   #1
Yarflana
Drives: 2008 Base Model
squealing belt, but a different question
Ok, I have read over and over about the startup squeal of the Yaris belt when it is cold.
I have put on a new Bando belt, but it still squeals. I read that you need to ensure the pulleys are dry and clean before installation of the new belt so as to ensure nothing is helping it slip.
My question is whether it is ok to use brake cleaner, sparingly, to clean off any residue from the pulleys (belt removed already of course).
Thoughts?
Yarflana is offline   Reply With Quote
Old 02-08-2014, 12:35 PM   #2
xavior686
xavior686's Avatar
Drives: 2012 Toyota Yaris sedan
I've been having this same issue on my 41k miles old Yaris. I turn the keys, & as SOON as the car's started I let go of 'em, yet the squeak still persists, though mostly only when it's cold outside or the car hasn't been cranked in like half a day & has cooled down.
Methinks it's coming from the belts, so I'll have to check it out.
xavior686 is offline   Reply With Quote
Old 02-08-2014, 01:44 PM   #3
Cleaning the pulleys is not a bad idea, in case a bit of oil got dripped from a prior oil change. If the belt is properly tensioned, but still squeals, that could indeed be the problem.
Brake cleaner would be fine if you sprayed it on a rag, rather than spraying it on the pulleys (where it could end up where it should not be). I typically use denatured alcohol for that type of cleaning.
Old 02-08-2014, 02:52 PM   #4
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I would go with OEM toyota belt and to get right tension requires a use of a pry bar makes sure you wrap the pry bar with the cloth and pry it against the engine mount.
Old 02-09-2014, 01:41 PM   #5
mtshum
mtshum's Avatar
Drives: Echo RS
Bando is an OEM belt for Toyota, if I remember correctly...
mtshum is offline   Reply With Quote
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 11:22 AM
Squealing Belt Noise Toyota3000 DIY / Maintenance / Service 3 07-23-2013 04:06 PM
squealing belt dferguson2 DIY / Maintenance / Service 9 06-20-2012 12:13 AM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 02:58 PM
Drive belt question toyo DIY / Maintenance / Service 4 02-22-2010 08:42 PM
