Old 03-30-2014, 12:10 AM   #1
vitzbitz69
Drives: White 2010 Yaris
MICROIMAGE Fog Light help please.
So on my 2010 yarii I ordered the MI fog light kit and followed the instructions step by step. BUT the fogs won't turn on.. When I hit the switch the light on the dash will turn on but the actual fogs will not. Any ideas? Thanks in advance!
vitzbitz69 is offline   Reply With Quote
Old 03-30-2014, 12:19 AM   #2
If the indicator is turning on, then the fog light relay is getting energized, as the indicator is driven by power flowing through the contact side of the relay. So, make sure that your two pins in the under-hood fuse box are installed in the correct positions and that your ground terminal is making good connection to chassis ground.
Old 03-30-2014, 12:26 AM   #3
vitzbitz69
Just checked both and still not working..
Old 03-30-2014, 07:59 AM   #4
Do you have a mulitmeter? I would check the voltage between the two pins on the connectors that plug into the bulbs. Also, take a close look at the bulbs to make sure the filaments aren't damaged from shipping.
Old 03-30-2014, 01:14 PM   #5
dumbo0
dumbo0's Avatar
Drives: Betsy - 07 Yaris HB
Where's the link to the pdf file for the DIY? Thanks in advance
WILDY imaginative
WONDERFULLY expressive
dumbo0 is offline   Reply With Quote
Old 03-30-2014, 01:28 PM   #6
http://microimageonline.com/forums/s...n-Instructions
Old 03-30-2014, 05:18 PM   #7
dumbo0
dumbo0's Avatar
Thanks scott
WILDY imaginative
Old 07-07-2014, 08:48 PM   #8
j-san
Drives: 2010 5-door hatchback
Sorry to resurrect an old thread, but I have a question that fits under the title of this thread. I just installed the MI foglight kit and everything works as it should under the OEM style install. I tried to change the wiring from "fogs on with low-beam only" to " fogs on with low and high beams". According to the PDF, I needed to connect the grey wire of the kit harness to the white/black striped wire on the bottom row, 4th position. I did that and the fogs now turn on independently of the headlamps.
I prefer my fogs to turn on and off with the headlamps so I don't accidentally leave them on a kill the battery. My Yaris is a 2010 5-door hatchback. Might there be a discrepancy between the years in the wiring?
Thanks.
j-san is offline   Reply With Quote
Old 07-16-2014, 12:28 PM   #9
j-san
Anyone know the answer?
Old 07-16-2014, 08:22 PM   #10
Thanks.
That is actually a typo on the install guide. Connect the grey wire to the white wire in pin 13, if the wire in the 4th position in the bottom row is not green.
Pin 13 is the white wire under the orange wire.
Old 07-16-2014, 11:47 PM   #11
j-san
Thank you very much, CTScott!
One question. If I want the indicator light in the switch to only light up when the fogs are on, would I just reconnect the switch power wires to the yellow and grey wires that come off the headlamp wiring? Basically, that would mean the LED in the switch would only get power if the fogs are getting power, right?
Old 07-17-2014, 09:07 AM   #12
No. That would make the light only come on when the fogs are off. With the indicator on the cluster, I don't see why you would want the switch light on when the lights are on. The purpose of the light is for finding the switch in the dark to turn the fogs on.
Old 07-17-2014, 04:16 PM   #13
j-san
I can find the switch just fine in the dark just by feel. I am used to having the switch light up when the fogs are on as that was how the driving lights switch was wired up on my previous car. It was an aftermarket install and the car never had the factory dash indicator so I had the lighted switch serve as my indicator. No big deal if the red LED stays on on the MI fogs switch. Just wondering if I could make the change.
Old 07-17-2014, 04:31 PM   #14
OK. To do that you would need to connect the switch's brown wire to one of the red wires on the back side of the fog light relay socket and the green wire to ground.
Old 07-18-2014, 05:30 PM   #15
j-san
Thanks a lot!
Old 07-20-2014, 11:30 AM   #16
insane_shroom
Drives: 2007 Yaris
So I installed the micro image fog lights on my 07 yaris and there are gals everywhere. Have you guys had the same issue?
This is just one side. But both sides look the same.
insane_shroom is offline   Reply With Quote
Old 07-21-2014, 03:47 PM   #17
j-san
Mine also had gaps around the top of the bezel. I don't think the gap on mine is as large as yours. I was going to try using a heat gun to warm up the plastic and try forming it by hand to make the gap smaller. That or use some of the 3M VHB tape to stick it in place. I don't think the gaps will have any negative effect on the fogs other than being an aesthetic nuisance.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
OEM Fog Light Brackets? xavior686 Cosmetic Modifications (Exterior/Interior) 15 02-16-2014 01:04 PM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 05:27 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
