Old 04-07-2007, 04:19 PM   #1
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Unhappy Problem with bumps?
Does anyone else have problems with the back passanger side suspention? When I have one passenger in my car and I hit the smallest bump only that one corner rubs. I currently have 205/50/16's on. I think it is odd that only that one corner rubs.
Is there any options that I could do? My idea right now it just get stiffer shocks for all four corners. Where can I get them? Also how much?
Thanks
P.s. I think I blew one of my original shocks. Working on the rigs is hard on the car, But unlike all the trucks I didn't get stuck.
nick1983 is offline   Reply With Quote
Old 04-07-2007, 10:58 PM   #2
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
yea the offset could be the problem....if they are out too far, they are probably hitting on the fender liner like mine are....
if you take pictures at different angles I can tell you whether the shocks and struts would fix your problem. I think new gas will fix mine because mines only with serious bumps and dips, and when im at a high rate of speed....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 04-08-2007, 03:16 PM   #3
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Thanks
I had this problem too. I think the car was not aligned properly from the factory. Of course it got worse when I lowered the car. I just got an alignment last week and now everything is fine. I can't say this will work for you but it might.
Galavoxx is offline   Reply With Quote
Old 04-09-2007, 06:50 PM   #4
nick1983
nick1983's Avatar
I want to buy some stiffer shocks and struts. What are available brands?
Old 04-09-2007, 07:02 PM   #5
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Use the search box. 1000's of spring options, but only one shock option that I know of, TRD.
SPONSORED BY
Old 04-10-2007, 11:23 AM   #6
nick1983
nick1983's Avatar
I called my toyota dealer, No shocks for the sedan yet. IDeas?
Old 04-10-2007, 12:51 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
call a different dealer, because the TRD setup has been out for a long time, ask for struts instead of shocks, helps ya sound like you know what you are talkin about
Old 04-10-2007, 12:57 PM   #8
nick1983
nick1983's Avatar
I will try the other 2 dealerships in the city.
Old 04-10-2007, 01:39 PM   #9
well, if it affects only one corner, there could be something wrong with the suspension, or wheel alignment for that wheel only. You should first take it to a dealer to check on that.
oh, and, do you go rallying with your yaris or something?
Old 04-10-2007, 02:16 PM   #10
nick1983
nick1983's Avatar
As fun as rallying in the yaris would be, I do not. Maybe if I had better suspension, I would.
Old 04-11-2007, 08:40 AM   #11
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
so then can you please explain how the car got so dirty???
d2dailly is offline   Reply With Quote
Old 04-11-2007, 10:50 AM   #12
07typeS
07typeS's Avatar
I had one too many burritos lastnight and my driverside front wheel rubs slightly, can anyone tell me what the problem might be lol...
I know why mine rubs, with just me front driverside. Two passengers, both front tires.
[QUOTE=eTiMaGo;73368]well, if it affects only one corner, there could be something wrong with the suspension [QUOTE]
Old 04-17-2007, 07:34 PM   #13
nick1983
nick1983's Avatar
It is my alignment. Took toyota 3 hours to repair it. lol
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 10:55 AM
Electronic Trunk Release Problem jonr0613 DIY / Maintenance / Service 5 09-08-2007 07:13 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 07:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
no tach= problem for newb? BrownNBubbly General Yaris / Vitz Discussion 19 05-18-2006 03:16 PM
