Old 04-06-2014, 01:17 AM   #1
NT05
Drives: 1nz-fe
Making it count.
Everyone enjoys music and has a different way to enjoy it and express it. In the end your speakers are the tell tale sign of quality that you have brought fourth to the table.
I am an avid Focal speaker user and a Audison BIT processor endorser. These are the heart of my system along with the new digital amps from Alpine. I'm more of an audiophile guy and like clean crisp sound so while I do like strong bass it's not my end result. Here are the pieces I use. Let me know what you think and or if you have questions.
NT05 is offline   Reply With Quote
Old 04-06-2014, 01:42 AM   #2
NT05
Drives: 1nz-fe
What it looks like when I set up my sound stage from my lap-top.
Old 04-06-2014, 11:23 AM   #3
NT05
Drives: 1nz-fe
The best digital amps I've ever used. Never gets hot, small in size and stackable. I have found nothing that compares to this Alpine line of amps. Pure clean clarity.
Old 04-06-2014, 02:19 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Well this is random.
Not that I disagree...
If I were to do my SQ setup all over again with mainstream components in mind, I'd probably use those Audison Voce amps off a Bit One.
Speakers are so absolutely subjective it's not even worth the debate. It's a Ford vs Chevy vs dodge thing honestly.
― Thomas Paine
Old 04-06-2014, 02:49 PM   #5
NT05
Drives: 1nz-fe
Sure, there can always be a speaker debate. But lets face it, there are still those companies that set them self above the rest and to some level even out of reach to the populous. I happen to like Focal for the price range and the upper end quality that you don't see in products like Kicker or the norm you find in Best Buy.
Old 04-06-2014, 06:07 PM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I agree, you gave diametrically opposing quality standard brands.
Focal (JM Labs), Morel, Audison, Dynaudio, HAT...they're all inherently engineered to a higher level than Kicker products. Let's compare apples to apples.
The last real Focal vehicle I heard that was great was Nick Wingate's VW at IASCA finals in 2011.
― Thomas Paine
Old 04-06-2014, 06:41 PM   #7
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Diamond Audio, CDT Audio, Phd, Ground Zero, Digital Designs Precision Power (amps).
Kicker is most def out of there League.
Old 04-06-2014, 06:59 PM   #8
NT05
Drives: 1nz-fe
Currently I'm using a 3way component set up front from Focal and a 2way Component set in the rear from Focal. My subs are a set of 6.5 JL in the doors and two 10" shallow mount JL in the hatch. Seems to do the job and clarity is up to par for my def-ass.
Old 04-06-2014, 11:04 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I remember when Diamond Audio was really good...I had their original hex series.
IMHO, the CDT plays too much off their passive crossovers. The issue I truly have is that they play a one size fits all which does NOT work well. This is absolutely why I like active setups. The flexibility to tailor the sound response without having to change out passive crossovers is so much more accurate and quick.
For me at this point, I'm playing with two way sets. I'm not even using a processor at this point. I miss using my Bit One. I can definitely hear the difference...especially in stage height, width and depth. I'm about to put the dual ID8 woofer setup back in the car...it's the same one I used at the world championships. It served me well and only got knocked down two points for the 20Hz extension. Bummer.
I never messed around:
I really used the P-01 for the true 4.99V at full tilt boogie. Sending fire down the lines (having the source at full volume [Voltage] at all times) to the Bit One and using the DRC as a volume knob more than anything is what my primary use for it was.
...and if I have skepticism on the truthfulness of the system, I have nearly two thousand pictures that detail three iterations of the car's builds...
If I was to do it again, I still have my mid range pillar setup that I've tweaked for another championship run. The sail panel tweeter mounts are gorgeous and ready to be used. I feel that I'm just waiting for the proverbial Bat signal to come back in, ruffle some feathers and leave some OGs with a bad case of hemorrhoids after I'm done with them.
― Thomas Paine
Old 04-07-2014, 01:19 AM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Tolm,
throw us some pics of the current setup...
― Thomas Paine
Old 04-07-2014, 09:45 AM   #11
NT05
Drives: 1nz-fe
Some how I don't think a 180.00 run of the mill Pioneer amp is even comparable to a 800.00 Alpine Digital series amp. If the system sounds flat try better speakers or a processor. The amp is not going to make it sound flat.
Old 04-07-2014, 03:20 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Not that I agree or disagree (at least at this point), but we need something to back up both claims (tolm & NT) of better sound...
...or are we talking from a point completely subjective experience?
― Thomas Paine
Old 04-07-2014, 03:35 PM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Now, in my experience with amplifiers, it's not the amplifier's power that changes the sound...One can accurately argue the signal Voltage does "change" the sound. Of course that is valid. It changes it with amplitude as that's what we perceive differences in the most accurately IIRC, but that amplitude isn't what we're referring to...
...but rather the crossover section or any on board EQ ability that changes the sound.
This is not all encompassing. What about Butler Tube drivers? "They sound warm!" Of course they do! You're listening to induced distortion...
Take "warm" and rename it "clutter" or "noise" and it doesn't appeal to most. Would I take a stab and run one? Oh hell yes! They have a certain ambiance and/or mystique (very much like running McIntosh amps). Oh but wait, that's all about subjective topics now isn't it?
― Thomas Paine
Old 04-08-2014, 12:36 AM   #14
NT05
Drives: 1nz-fe
Good point Sqcomp. I'm still just not under the impression that a 180.00 Pioneer amp is up to the task. May as well buy a kicker.
Old 04-08-2014, 11:18 AM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I would tend to agree in a general sense.
What I'm usually going for in my purchase of an amplifier is build quality first, dynamic delivery in terms of Voltage/output, and then features.
For me, I'd be in competition bliss if I could find an amplifier that was simply just that, an amplifier. No bells or whistles to alter the sound. Where I am now...I don't truly give a F what others think. I'll flip on competition mode and eat souls if I choose...
― Thomas Paine
Old 04-08-2014, 11:34 PM   #16
NT05
Drives: 1nz-fe
Well, time to get my truck together with a new GPS head unit, so I went with Kenwood for it's use with Garmin maps.
Old 04-09-2014, 01:32 AM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
What else is going in?
― Thomas Paine
Old 04-09-2014, 10:11 AM   #18
NT05
Drives: 1nz-fe
Keeping my truck simple nothing real high end as far as processing or competition is concerned. Using Alpine S series for front and rear speakers and Alpine R separate tweeters up front as well. The Sub is a 10" MB Quart and my amp is a PDX9 from Alpine. Like I said, keeping it simple but still running quality components.
rear suspension making knocking noises jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-18-2011 01:00 PM
'08 3dr 5MT Making a Sound Like a Propeller! TheSilkySmooth DIY / Maintenance / Service 2 05-26-2010 12:31 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
