Old 04-08-2014, 10:28 PM   #19
Originally Posted by mpcv2000 View Post
I know I will sound nob but I'm not use to Toyota stuff , name , abbreviation , etc.
What means "EWD" and "EPC".
The only time I've mess with Toyota parts it is when I was working on my swapped RX7
EWD - Electrical Wiring Diagram
EPC - Electronic Parts Catalog
Old 04-09-2014, 07:03 AM   #20
mpcv2000
mpcv2000's Avatar
Drives: 2004 Echo HB Hatchback 2 Door
So it is that easy ?
Example:
I tap the White & Green from Connector C13 on the 2005 ( # 2 ) to White & Green on the 04 Pig Tail C13 ( # 2 ) and so on
B - Black
R - Red
Y - Yellow
W - White
L - Light blue
O - Orange
Br - Brown
G - Green
V - Violet
color1-color2 = Color1 with color2 stripe
For RPM Signal is it right to say I tap the Black wire from the OBDII port to pig tail # 15 on the C13 Connector on the 2005 ?
As of Hi/Low Beam I just have to find the positive wire from the Hi/Low switch and send the signal to #15 on the C13 connector from the 2005 Pig Tail ?
If it is right I'll try to do that this week end.
Thanks a zillion times for helping me on this.
mpcv2000 is offline   Reply With Quote
Old 04-09-2014, 07:56 AM   #21
^Exactly. With that extra set of pig tails it really is not bad at all.
Old 04-09-2014, 07:58 AM   #22
mpcv2000
mpcv2000's Avatar
Can't wait to start working on this.
I owe you one.
Old 04-10-2014, 10:01 PM   #23
mpcv2000
mpcv2000's Avatar
Decided to give it a try tonight ( Thursday April 10 ) .
I'm not good with electricity and wires so just for people to know , numbers on the pigtails are when you are facing them.
Took my RPM signal on the Black wire on the OBDII port.
Because I wanted to shrink all connections , I had to cut my 04 Harness to be able to slide a shrink tube on it and solder the 05 harness on the 04.
Et voila .
Now with RPM
A big thank to CTScott who gave me all info and diagram to do that , without him I would have never been able to do that because I suck in electricity.
Your pin numbers were right on but there is some typo on some color on your chart so if someone else do that just follow the pins and connector's number and it will work at your 1st attempt.
I just have to wire the Hi/Low indicator and I'll take the cluster back off to remove the Blue indicator when the car is cold.
I had removed it on the 04 cluster. It is annoying.
I didn't take the car out but everything appears to be working.
Old 04-10-2014, 10:13 PM   #24
Nice. Which wire colors did I have the typos on, so I can fix the chart for the next person crazy enough to give it a shot?
Old 04-10-2014, 10:24 PM   #25
mpcv2000
mpcv2000's Avatar
05 w/tach color , pin numbers are right on.
04 w/o tach pin numbers are right on and the color should be the same as the 05 .
Don't forget that I have a Canadian car so it can be different than in the USA but every pin number you gave me on the 04 & 05 were color match , each and every one of them.
I had to cut 31 wires on my main harness and the merge I did with the pig tails were all color matched.
I'd say it was a easy project.
Thanks a lot for your help.
Old 05-06-2014, 06:47 PM   #26
mpcv2000
mpcv2000's Avatar
May 6th 2014.
Put the key in the car and noticed the cluster a 90,000 clicks even .
I think it deserved a picture.
Love the 05 Cluster .
Old 05-07-2014, 08:21 AM   #27
IllusionX
Drives: 07 Yaris Sedan Aero
Seriously.. everything works out of the box? It took 3 attempts in 8 years before someone made it to work properly?
Did you also check your speed vs GPS?
btw, you may want to try to reregister on clubecho-yarisquebec..
Old 05-07-2014, 08:25 AM   #28
mpcv2000
mpcv2000's Avatar
It worked on 1st attempt.
The only thing I haven't done yet is the Hi-Low Beam wiring , I may do it later on when I'm bored and yes everything works like if it came like that from the factory.
I haven't check with a GPS but I don't see why speed should be different
Old 05-07-2014, 08:28 AM   #29
mpcv2000
mpcv2000's Avatar
I have to add that without CTScott I would not have been able to make it work so easily.
Old 05-07-2014, 09:56 AM   #30
IllusionX
Because other member at clubecho-yarisquebec said he had a 20kmh difference in the speedo.
Old 05-07-2014, 10:23 AM   #31
mpcv2000
mpcv2000's Avatar
I'll try to check it this week but according to traffic flow it appears to be right on but I'll check for sure.
Old 05-07-2014, 01:38 PM   #32
My bet is that they messed up the ground connection for the speed sensor to cluster connection. Based on the specs for the signal output in the service manual, there should not be a difference between the two.
Old 05-07-2014, 04:18 PM   #33
mpcv2000
mpcv2000's Avatar
Maybe they mean .02 KMH
I don't have stock tire size so it may read off a little because of that.
Here's what I have : Nitto NeoGen 205/50R15
It's right on.
Now I want some disk brake on the rear .
What is my best option ?
Budget is between $600.00 to $1000.00 .
I have Goggled it a little on it but nothing "easy to grab" came up really.
Old 05-07-2014, 04:27 PM   #34
IllusionX
i would fine a complete rear axle off a Yaris TS from europe.
Old 05-07-2014, 05:10 PM   #35
mpcv2000
mpcv2000's Avatar
I would find a complete rear axle off a Yaris TS from Europe.
Any specific years ?
I'm not very familiar with the Yaris TS in Europe , neither am I with the Yaris in North America to be honest .
Old 05-12-2014, 03:30 PM   #36
AlaxyGalaxy
Drives: 2004 Echo HB 5-door
It has 87,000KM and the seller gave me the 2 pigtails from the 05 with about 10" of wire and he had marked one wire that I had to take the signal from the Black wire on the OBDII port to get my tach signal and he also said maybe the Hi/Low beam indicator may not work unless you re wire it.
Does the odo mileage stay with the cluster or is it stored in the car's computer?
I want to do the same swap as you, but I want the actual odo reading to stay with the car.
AlaxyGalaxy is offline   Reply With Quote
Yaris Liftback cluster w/tach for SALE!! jose3sgte Items for Sale by private party 5 11-13-2013 10:35 AM
Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS Jabro Willing to Buy by private party 4 12-21-2012 06:34 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
2007 Yaris Sedan cluster, with Tachometer. (Won't fit Liftback) H3LlIoN Items for Sale by private party 3 09-18-2011 03:55 AM
