Old 06-02-2014, 09:10 PM   #1
LeetViet
Drives: 07 Yaris 4DR
How do I fix the plastic under my front bumper?
I'm not sure how it got broken, but the plastic under my front bumper is hanging. I've temporarily zip tied it to the front bumper. There's also a hole in (what I believe is called) the front right wheel well.
Could anyone tell me how I can fix the wheel well, and the plastic under my front bumper? Is this an expensive fix?
Images (very large):
http://i.imgur.com/cAtCs9v.jpg
http://i.imgur.com/eA8uTm3.jpg
http://i.imgur.com/yEPYRQh.jpg
LeetViet is offline   Reply With Quote
Old 06-02-2014, 09:39 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
only thing u can really do is replace the liner in the wheel well and the center one also u will need hardware with it...no crazy expensive but not cheap from Toyota , ur best best is go to wreckers and see if u can locate one.
Old 06-02-2014, 10:38 PM   #3
alanwagen
argghh
One of the more irritating things about the Yaris. I just have patching my son's with cable ties also. He messed his up but good, but he is also cheap.
See how it goes with the cable ties, your does not look so bad.
Old 06-03-2014, 01:38 PM   #4
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
yep
mines been like that for YEARS ever since I hit a dead deer and went AIRBORNE!
trunkout is offline   Reply With Quote
Old 06-03-2014, 03:06 PM   #5
bronsin
bronsin's Avatar
You HAVE fixed it!
Old 06-04-2014, 02:51 PM   #6
esse10
Drives: 2009 yaris 2 door
mine also
Mine has been hanging with cable ties also for the last 1.5 years. It's mainly a splash guard for when it rains It really does not matter too much unless you plan on entering a show contest then the judges might have an issue with your cable ties holding up stuff. LOL The hole in the wheel well might need to be patch up mainly to keep water and road grime/mud from entering the engine area especially the serpentine belt/pulleys.
esse10 is offline   Reply With Quote
Old 06-04-2014, 04:12 PM   #7
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
I have removed everything that's plastic underneath my car up front... :P even the wheelcases.
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 06-04-2014, 05:00 PM   #8
alanwagen
interesting
so have you had any problems with that? This seems like an option.
Old 06-04-2014, 06:17 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
unless you are a total clean freak, the engine bay will get awful dirty awfully fast. The thing most of that plastic does is keep out dirt and other crud.
Colin Chapman disciple
Old 06-04-2014, 06:43 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
dont remove it i see what happens when u do , there is a good reason for it unless ur car does not see rain and is a show queen... just fix it.
Old 06-06-2014, 12:06 AM   #11
LeetViet
UPDATE: Took her to the dealership, and the cost is $391+tax (labour included). Will think it over.
Old 06-06-2014, 12:09 AM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
ya its crazy , try the junk yard it will fit from any yaris 06 to 2011
Old 06-06-2014, 06:11 AM   #13
G-Ammo
G-Ammo's Avatar
My engine isnt getting that dirty, but I'm driving very low, so most things cant really get in the engine bay (+ I keep the engine bay quite clean).
And I never had any problems without it... :D
There's a plus side about it: because the plastic isn't holding the front bumper I now have a bit of movement in it, so when hitting curbs or speedbumps (or whatever) the bumper bends with it :)
Speedbumps suck...!
Old 06-10-2014, 09:10 AM   #14
esse10
omg
omg $391. why not just patch it up with a piece of hard plastic and put a few ty-wraps to hold it on there. Or if you know the part numbers just find it onine through ebay.
Old 06-10-2014, 12:39 PM   #15
nortonfb
Drives: 2007
Got a solder gun?
There is plastic welding. Weller makes a heat tip for plastic. Fill material is a handful
of plastic straws, available at your local Mickey D's. You may need some reinforcement.
Since it' s under the car it doesn't have to be pretty. I have used JB weld with success.
You can try & source a used piece of similar material and use that as fill or for bridging.
Norton
nortonfb is offline   Reply With Quote
Old 01-06-2017, 12:48 PM   #16
cherrmj
Drives: 2010 2Dr
Correct Fit and install concerns
Hello all, My daughter has a 2010 2Dr Hatchback. Both front sides need Wheel well splash gaurds. A couple of questions please.... When ordering online how do you increase your chances of getting the correct fit and what site? Any links or instructions to install? Both sides are currently missing. Thanks Much!!!
cherrmj is offline   Reply With Quote
Old 01-06-2017, 05:11 PM   #17
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I start with Village Toyota (villagetoyotaparts.com) to look at diagrams and confirm part numbers. Once you have the right part number, you can get the part from any dealer or distributor.
Old 01-07-2017, 05:52 PM   #18
jra
Drives: 2015 yaris L
You could put a patch over the wheel well hole, lock tight and others make epoxy for plastic, I've used lock tight brand a few times with susses.
jra is offline   Reply With Quote
Front bumper question sherryberry DIY / Maintenance / Service 4 04-14-2012 01:59 PM
FS: KavinT Manseth Kit (Front Bumper Damage) LIMITED TIME PRICE! Treyz Items for Sale by private party 7 07-20-2010 04:57 PM
New mod: half silver front bumper paint job! SAV912 Photo-Video-Media Gallery 9 07-18-2010 01:57 AM
FS: KavinT Manseth Kit (Front Bumper Damage) LIMITED TIME PRICE! Treyz Items for Sale by private party 3 05-26-2010 09:43 PM
What do you think? painting the front of a Yaris hb front bumper black like the GTI Rnankoo Cosmetic Modifications (Exterior/Interior) 15 08-23-2009 06:49 AM
