Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Cars for Sale by private party
Old 06-02-2014, 10:25 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
2009 Toyota Yaris Absolute Red
2009 Toyota Yaris
Body Style: 2/3 Door Hatchback
Color: Absolutely Red
Millage: 75,***
Engine: 1NZ-FE 1.5 liter
Transmission: 5 Speed Manual
MPG is dependent on driving style anywhere from 28MPG to 42MPG depending on conditions. I get 32MPG, mixed driving.
^photo taken 06/01/2014
Full Synthetic Royal Purple Oil since 35,000 miles and Royal Purple Gear Oil change at 50,000 Miles
Handling:
15''Drag DR21 w/Nitto NeoGen 205/50R15
Tanabe DF210 lowering springs 1.6/1.8
TRD Rear Sway Bar
Tanabe Front Sway Bar
Tanabe Front Strut Tower Brace
Whiteline Stabilzer/swaybar adjustable end links
Performance:
Micro Image Short Throw Shift Kit (both in cabin and on transmission),
8.64lbs flywheel
F1 Stage 4 Clutch
AEM Cold Air Intake (Red)
Megan Racing Header, ARP Manifold Stud Kit
DC Sports Axle Back Exhaust
Micro Image Crank Pulley
NST lite Alternator Pulley
NRG Grounding Kit (Red)
Appearance, Convenience, and Safety:
CF Hood
ScanGuage II
Micro Image Silicone Radiator Hose Kit (Red)
NRG Carbon Fiber Shift Knob (round)
2009-2011 Toyota Yaris Lift back Fog light kit
Hella Horns (Red)
now with 35% tent with 99% uv blocking
original build thread
http://www.yarisworld.com/forums/sho...highlight=head
Selling as a whole, if you wish to part it out you may after you take possession of the whole car.
listing at negotiable USD Shipping not included
YW member Negotiable Shipping not included.
Offers welcome.
I have all of the original parts (except the clutch, flywheel, and steelie rims) including the original springs that where taken off the car before 500 miles where even put on it.
Last edited by Golddeenoh; 03-23-2017 at 11:03 PM. Reason: adjusted miles some more
Old 06-02-2014, 10:27 PM   #2
Golddeenoh
Golddeenoh's Avatar
Spy Photo
Old 06-02-2014, 11:23 PM   #3
ohiostate0924
Drives: 2008 Toyota Yaris
Very Nice...If you don't mind me asking what type of paint did you use to paint the interior parts that the radio sits between....I was wanting to do this but have no clue which paint would be best....Thanks...
ohiostate0924 is offline   Reply With Quote
Old 06-03-2014, 09:18 AM   #4
Brett!
Drives: 2010 3D base
looks like it was plastidipped.
Great price man, makes my yaris fs post look weak
Brett! is offline   Reply With Quote
Old 06-03-2014, 01:17 PM   #5
MyzticZ3r0
You can use any paint color you wish. It's all in the preparation that'll matter - you should sand the pieces with a 200-300 grit, then a 400 grit, and finally to a 600 grit. The surface should be smooth enough where once you apply primer, the actual paint will adhere to the primer, and then gloss to finish the pieces off.
Short version:
clean pieces, sand, sand, sand, apply primer, paint, gloss.
MyzticZ3r0 is offline   Reply With Quote
Old 06-03-2014, 03:14 PM   #6
Golddeenoh
Golddeenoh's Avatar
I used spray paint that was matched to the color of the car. I had t sand down the trim pieces to remove the factory texture and then applied 3 coats of primer, 3 coats of "Super Red V", and then 3 coats of clear. Giving each coat plenty of time to dry before the next coat/color/clear. took me about 3 days for all of it.
nope, i didn't plasti-dip anything on the car.
Short version:
^quick guide, just remember not to rush any of it, or it wont look as good as you want it to.
Old 06-03-2014, 11:29 PM   #7
ohiostate0924
Thanks for the responses I appreciate your responses, I should have asked this question the first time, I know the pieces pretty much snap off and I have to unplug the Hazard button and Seatbelt/airbag thingy but do they come out as well or do I need to tape over them to not get paint on them ?? Sorry again for the questions, I believe that is all I need to know, thanks again....
Old 06-03-2014, 11:38 PM   #8
nookandcrannycar
Have you already picked out your next car ?
Old 06-04-2014, 09:01 PM   #9
Golddeenoh
Golddeenoh's Avatar
Yes the come out so you don't have to tape off anything on the front.
maybe
Old 06-06-2014, 12:57 AM   #10
nookandcrannycar
Originally Posted by Golddeenoh View Post
maybe
Old 06-13-2014, 10:01 PM   #11
Golddeenoh
Golddeenoh's Avatar
price adjustments and wording updates
Old 06-19-2014, 02:14 PM   #12
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Smokin' deal on a Smokin' Yar !
Good Luck with sale, great pricing and low miles
For me, the hatch and red paint are deal killers
No red cars for me, won't do it
N I love my sedan
But, if I was lookin, only the red paint would have me at bay....
Nice Yar!
Old 06-19-2014, 08:40 PM   #13
Golddeenoh
Golddeenoh's Avatar
I've had it 5 years, and never been pulled over. red means very little as long as you dont give a reason to be stopped.
Old 07-02-2014, 09:13 PM   #14
Golddeenoh
Golddeenoh's Avatar
just keeping it fresh
Old 08-05-2014, 09:35 PM   #15
Golddeenoh
Golddeenoh's Avatar
this car beats FRSs daily
Old 10-14-2014, 07:39 PM   #16
Golddeenoh
Golddeenoh's Avatar
at this rate i might as well keep it so i can afford to drive.
Old 12-17-2014, 10:48 PM   #17
Golddeenoh
Golddeenoh's Avatar
installed new end links
Old 12-18-2014, 01:56 AM   #18
ctsround3
YARLY!
ctsround3's Avatar
Drives: 2009 Carmine Red 3-door Yaris
Sadly, I have your asking price invested in my 09 with double the miles and half the mods. Good deal though, GLWS
2009 Carmine Red Yaris | Tein S-Techs | Tokico Blues | TRD Rear Sway Bar | RS Replica Spoiler | 16x7 Konig Feathers | Stay tuned..
ctsround3 is offline   Reply With Quote
Cruise control on 2009 Toyota Yaris dholton In Car Entertainment + Electronics (audio / video / alarm) 16 04-04-2023 04:27 AM
2009 Toyota Yaris OEM Cruise Control DIY BentSpace DIY / Maintenance / Service 7 04-16-2014 10:05 PM
2011 Toyota Yaris Hybrid tuckevalastin General Yaris / Vitz Discussion 48 03-30-2009 08:42 AM
