#271 | |
4 years of P90X!
09 sedan no wires???
I will post pics tomorrow on the install...... |
#272 |
![]() Drives: 2007 Toyota Yaris 4dr Join Date: Mar 2014
Ok I have a 2007 Yaris four door. This looks like a cool mod but i do have one question. Do you not have to have the cruse control vacuum actuator to hold the throttle cable down when you hit the set button? Or is the computer using the throttle position sensor and locking the voltage in at that point? I hope this makes since.
#273 | |
So, for your 2007 (and any US/Canada Yaris 2006 to present) what is documented in this mod, or for a few more dollars adding the OEM stalk will give you cruise. This DIY discusses the OEM stalk method. I carry all of the parts for doing that route for quite a bit less than dealer pricing. http://www.yarisworld.com/forums/showthread.php?t=33750
#274 |
4 years of P90X!
Seriously!?!?!
That was so easy it's scary. Ten minutes tops. All parts ready at radio shack. 8 bucks.
#275 |
Post a picture of how you wired your switches and your connections to D3. It does sound like you have an issue, as the horn pad grounds to black wire to make the horn honk.
#276 |
![]() Drives: Scion TC Join Date: Nov 2014
Hope you don't mind a question from a non-Yaris owner?
Great thread! I imagined a ~$10 mod would look like it but it's every bit as aesthetic as functional. I installed an oem kit stalk and it's almost in the way compared to dash buttons. The basic Scion TC "CRUISE" light does not have a "SET" indicator. Is it possible to add a single LED as a "SET" indicator without having to tap the CAN circuit? |
#277 | |
#278 |
Cool. My ECU diagram lists CAN L and CAN H. Would a voltage test during cruise "set" indicate which CAN could be tapped for the hot side of the LED? Opposite side of LED to ground?
#279 | |
What year is your TC?
#280 |
Are we talking wave form instead of voltage? I probably better stick with the basic cruise light.
The TC is a 2008 'spec'. Thanks for the info. |
#281 |
Even more than wave form - We are talking about an encoded message within a stream of pulses. I actually have an enhanced version of my cruise control indicator module that I developed, which can drive separate LEDs for ON and SET. I haven't offered it for sale as of yet, as it is a $50 device, as opposed to the $25 one that just handles reading "ON" via the feed between the switch and the ECM. Set is more complex, as you really need the message feedback from the ECM to know that all conditions were met to allow the ECM to set it.
#282 |
Thanks for the info. Any plans to make the 'set' indicator available separately?
#283 |
I can easily do that. It is just a matter of not having the second LED for "ON".
#284 |
Dear CTScott,
Was wondering if this idea could be applied to remote audio controls, (ie seek/volume) without having to fork for the steering wheel upgrade? My head unit has the wires that typically go to the clockspring. The volume dial has to be turned too many times to be useful. I'd like to have an up/down rocker-type control if possible. I thought about using two rockers for volume and seek plus a momentary switch for the "mode" selector. Is this possible without adding resistors to the switches or does the head unit require variable voltages to know which switch is being pushed? Last edited by 62Fender; 12-18-2014 at 09:18 PM. |
#285 | |
#286 |
![]() Drives: Toyota yaris Join Date: Nov 2010
CROUSE
can this work with vitz 2005 2SZ-FE SMARTKEY(KEYLESS ENTRY START BUTTOM) NO KEY AND IGNITION SWITCH HOLE
#287 |
No. There is no easy cruise solution for the Vitz.
#288 |
If pin 40 is zero volts, then your only option is an aftermarket solution, such as the original Rostra kits (the kits with the non-OEM looking stalk).
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
