Old 06-15-2014, 12:19 AM   #2773
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
SQcomp, if you are out there and your friend willing to answer some questions about horns...
Is it a requirement for the horns to run parallel to the floor of the car, or can I install them slightly upwards, not much like 3 or 4 degrees?
Thanks
D.
CLA 250, 4MATIC
Old 06-15-2014, 03:22 AM   #2774
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Let me forward the question...
I'm out in the back hills of Washington firing field artillery. The answers might be a little slow.
― Thomas Paine
Old 06-15-2014, 03:34 AM   #2775
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I preferred not to be looking down the throat on any horn. Parallel to the floor seemed best.
The reasoning is the point source efficiency may over power your ears...also, watch yourself below 1k on the horns.
― Thomas Paine
Old 06-15-2014, 03:48 AM   #2776
derickveliz2
Thanks,
I guess you are right, I've been reading a little bit and it seems that the horns need to run parallel to the floor.
What do I need to be aware of below 1kHz?
I hope you are having fun!
D.
CLA 250, 4MATIC
Old 06-16-2014, 03:12 AM   #2777
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Be ready to replace diaphragms if you go too low...
― Thomas Paine
Old 06-19-2014, 01:08 AM   #2778
derickveliz2
The guy who sold me the Horns suggested to try from 600 Hz to 800 Hz and see how it sounds in my car, this suggestions are for the Full size bodies!
D.
CLA 250, 4MATIC
Old 06-19-2014, 02:41 AM   #2779
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Have fun with it.
The horn bodies aren't what I'm concerned with. It's the movement on the diaphragm using lower frequencies...
Think trying to play below 1kHz on a big tweeter and then compensating for the frequency response on the bottom end with EQ. I'm not saying below 1kHz can't be done, rather it may be more stressful than needed depending on the frequency response of your other speakers.
Just be careful, that's all. I say start at 1kHz on a 24dB crossover slope and then experiment with lowering that point little by little.
― Thomas Paine
Old 06-19-2014, 02:46 AM   #2780
derickveliz2
I will,
I'm still far away from fire them up, but it's nice to plan and design.
Will start very conservative then push the limits (safe)
Now on my drawing board is how to make a mold from the glove compartment and then make a copy with fiber glass.... cut a hole and install the P99 inside. Any ideas?
Thanks
D.
CLA 250, 4MATIC
Old 06-20-2014, 03:09 AM   #2781
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I would buy a spare glove box to make a mold off of first. Never use the original...too many things to go wrong...
Get that and we'll look at how the OEM box comes apart...THEN we'll look at making a mold or a one off. I might want to lend a hand somehow...
― Thomas Paine
Old 06-21-2014, 01:40 AM   #2782
derickveliz2
I wish I could just by a spare, been the CLA such a new car it's almost close to impossible to get parts at this moment.
Taking the glove box out it's simple, I'll try tomorrow to take it out and see how many curves are involve, my concern is negative shapes that would make the mold stick to much for an easy release.
LINK for VIDEO
or
http://youtu.be/o4YLmswBHx0
D.
CLA 250, 4MATIC
Old 06-21-2014, 02:09 AM   #2783
derickveliz2
Check this out! 11 miles commute, most of it was highway and no traffic... 45 MPG
D.
CLA 250, 4MATIC
Old 06-21-2014, 03:39 AM   #2784
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Then we could probably do it in sections...
― Thomas Paine
Old 06-24-2014, 11:17 AM   #2785
derickveliz2
I got into the Engineering Mode, and found this screen, but I'm trying to find out what's going on, there is one for each set of speakers, Front Left, Front Right, Rear Left and Rear Right... any guess?
D.
CLA 250, 4MATIC
Old 06-25-2014, 03:01 AM   #2786
sqcomp
Roadrunner Jr.
sqcomp's Avatar
How many speakers does your stock system have? That is the first thing I'm thinking of when I see that.
― Thomas Paine
Old 06-25-2014, 03:25 AM   #2787
derickveliz2
The image above it's only for the Front Left (6.5" in door + Tweeter in Sailpanel)
Then there are rear 6.5" in rear doors, left and right)
D.
CLA 250, 4MATIC
Old 06-25-2014, 03:27 AM   #2788
derickveliz2
Bad news about the Glove compartment!
Yes it comes out, but the lower Airbag comes with it )o:
Back to the Drawing table!
D.
CLA 250, 4MATIC
Old 06-26-2014, 09:32 AM   #2789
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Damn Germans! Always making things complicated. :)
― Thomas Paine
Old 07-04-2014, 01:23 AM   #2790
derickveliz2
That's ok, I'm not going to do anything with the stock radio any way.
I'm struggeling to get the Horns past the Air Bag under the dash, it's so close, I'm going to have to use the knife to find out!
some pictures of the body for now...
Here... next to it's big brother...
D.
CLA 250, 4MATIC
