Old 06-16-2014, 01:03 PM   #1
WildChild
Request: Picture of the transmission end of passenger CV axle
Hi,
after requesting some information on changing my driver side CV axle (http://www.yarisworld.com/forums/showthread.php?t=51635), I got a weird new issue.
Basically, when putting in the new driver side axle, the right axle got dislodged and transmission fluid started to leak. Any idea how it could have happened?
I put it back in place using a screwdriver and a hammer to hit the notch used for this purpose, but now fluid seems to leak when I'm driving and I can see a few drops on the ground a few hours after parking the car. I have the feeling that the axle might not be well seated in place.
Does anyone have a picture of the connection between the transmission and the axle so I can compare with mine?
Thank you!
WildChild is offline   Reply With Quote
Old 06-16-2014, 01:19 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
sounds like u have pinched the axle seals in the transmission on the right side or both , have a closer look at where the leak is from and if so replace seals . You will have to remove the drive shafts and after the seals , pry them out and use something to push /punch back the new once also dont forget to top off ur trans fluid ...bet its low now too.
Old 06-16-2014, 01:35 PM   #3
WildChild
I find it hard to believe it would have been pinched, but we never know... It got dislodged but the shaft did not go out completely. I guess it could have damaged the seal anyway.
Transmission fluid is definitely not low. I also drained/refilled it last weekend and drove 350KM without any noticeable loss.
Is it possible to remove the drive shaft from the transmission without removing everything on the wheel side (especially the axle nut)? I have in mind loosing the hub from the suspension but keeping the drive shaft attached to it. If not, I'll plan accordingly.
Is passenger drive axle hard to change? DeathBeard DIY / Maintenance / Service 8 10-01-2016 09:06 PM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 11:43 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
Picture request: DC Sports exhaust on a sedan. Herbicidal Performance Modifications 7 02-09-2010 12:44 PM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 08:22 PM
