Q(','Q)
A friend of mine told me that after changing from stock(steelies) to bigger aftermarket rims (Konig Feathers 17x7) my sparetire is pretty much useless.
Is that true??? If so am I SOL when I get a flat? Last edited by eijikikimaru; 04-12-2007 at 03:27 PM. |
Yea actually I like to know this myself so I can take the weight out of my trunk.
-- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
i don't see why it would be useless, maybe you just have to be extra careful since the overall diameter of the Konig's are larger than the OEM steelies.
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
It will be fine. Your friend is useless, not the spare.
Q(','Q)
Nice 1
-- Blen
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
yeah, it is fine
i do wish a full size spare fit back there like in my Golf but the donut is fine, you won't be driving on it long anyway
SPONSORED BY
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
May want to keep a set of stock lugs with your spare....something to check out if your new wheels got different types of lugs.
____________ Old School Cobble Jockey
Don't forget it's best to put the spare on the rear. If you get a front flat, put a rear on the front, then replace the rear with the spare. You don't have to do this but it is better for your tranny.
#10 | |
Exactly, and be sure to keep two socket sizes or two lug wrenches if the lug nuts are different sizes. I carry a breaker bar and socket for the lugs on my aftermarket rims, and left the stock lug wrench in the car for the spare tire lugs. |
If you've chose your aftermarket rms and tires wisely, and the overall diamter remains the same, or very close to the stock wheels, no problem.
Good point about keeping spare lugs as well, I'll have to check that myself, it would suck to not be able to attach the spare properly!
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
most tuner lugs used on aftermarket wheels work just as well as the stock lugs, so there is no need to keep the stock lugs in most cases, long as your aftermarket lugs have a bulge seat, and not a shank you will be fine... again it all depends if you had stock steelies or aluminum, cause Toyota uses shank lugs on aluminum wheels and bulge seats on steel
Break'em off some.
Good preventative info here. If you can, put the spare on the rear if you have a front flat tire, as it is better for the differential. If you can't don't worry about it too much.
If you have "tuner" style lugs they will work fine with the spare donut. Just make sure you have tht capability to REMOVE the tuner lugs in the event of a flat. I have splinedrive lugs and the key for them fits in the breaker bar that came in the tool bag. |
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 07:29 AM |
| All season or Summer tire? | GabL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 03-10-2007 12:07 PM |
| Tire Fitment question | Ryu | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 01-14-2007 02:47 AM |
| Flat tire, totally ruin help | David81 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-15-2006 02:54 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
