Old 11-04-2014, 11:59 AM   #37
finnpoulsen
Drives: yaris 2sz-fe
Thanks a million CTScoot!
Had to go through the procedure a couple of times until i realized that the door had to stay open between some of the steps
finnpoulsen is offline   Reply With Quote
Old 04-18-2015, 08:24 PM   #38
kimouette
Drives: Toyota Yaris 2007 LE liftback
Hi,
I just bought a 2007 Toyota Yaris liftback...
I have a remote car starter but the lock/unlock function doesn't work. It makes the lights flash but it doesn't unlock the doors.
I have tried to reprogram it by following CTScott's post, but the doors dont lock/unlock at the end of the procedure.
Any help would be greatly appreciated!
Thanks
Kim
kimouette is offline   Reply With Quote
Old 04-18-2015, 09:18 PM   #39
Originally Posted by kimouette View Post
Hi,
Thanks
Kim
Do you have a separate remote for the remote starter and the genuine Toyota keyless entry remote?
Old 04-18-2015, 10:12 PM   #40
kimouette
I have only one remote and it's not a genuine Toyota keyless entry remote (FCC ID : EZSNAH1501).
Do you think they could have only installed the remote car starter and "forgot" or purposely decided not to install the lock/unlock feature? Cuz when I press on that button it makes the car lights flash instead of locking/unlocking the doors.
Old 04-18-2015, 10:16 PM   #41
First off, if it is not a genuine Toyota remote, the procedure above would never work.
It is very possible/likely that they did not hook up the lock/unlock. Does your car have power locks?
Old 04-18-2015, 10:42 PM   #42
kimouette
Yes it does
Old 04-18-2015, 10:54 PM   #43
Yes it does
OK. In that case I would pop open the cover under the steering wheel and see if you can find the module for the remote starter to see what is and is not connected to it.
Old 04-18-2015, 11:09 PM   #44
kimouette
Ok I'll do that first thing tomorrow. I will take a picture cause I really don't know what i'm looking for
Old 04-19-2015, 08:45 AM   #45
kimouette
Here are the photos :
https://plus.google.com/u/0/photos/1...92190491869509
Does this look like a remote car starter module?
Old 04-19-2015, 09:10 AM   #46
That is definitely it. Now you need to find the make and read the model number off it, then you can find the manual for it and see what wires are for the lock/unlock.
Old 04-19-2015, 10:32 AM   #47
kimouette
I cant find the brand name on the module.
Here's a photo of what I see :
Unfortunately with these information I cant find any manual!
Old 04-19-2015, 01:19 PM   #48
nortonfb
Drives: 2007
This may help and here is a recall on that model.
http://www-odi.nhtsa.dot.gov/acms/cs...E045-5133P.pdf
nortonfb is offline   Reply With Quote
Old 04-19-2015, 05:49 PM   #49
It is definitely an AutoStart brand one, bu the OB-2481 model number does not seem to be a current one. You could try calling them to see if they can give you any info on it:
http://autostart.ca/AboutUs.aspx
Old 04-20-2015, 07:41 AM   #50
kimouette
Ok so I found the wiring plan : http://autostart.ca/asdocs/2W_FM_LED..._en_h50s44.pdf
Which confirms the lock/unlock is simply not wired. Who would do that?? I mean break his back wiring a remote start and stop for a coffee and say "hmm lets call it a day".
Would you recommend a newbie like me to buy the wires and plug them in? Or should I leave that to a professional and pay the price?
Old 05-22-2015, 11:42 PM   #51
island_Vitz
island_Vitz's Avatar
Drives: 2010 Vitz 9AE
nvm
island_Vitz is offline   Reply With Quote
Old 05-11-2025, 10:13 AM   #52
Clintondmb
Drives: '08 3DrLB.
Had this happen recently. Ended up pulling the battery cable and that corrected the issue. Probably the airbag recall was the last time the cable was taken loose about eight years ago. I have a ten year old optima in there.
Clintondmb is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Help! Keyless entry on a 2007 liftback?! sd_007 DIY / Maintenance / Service 4 05-28-2009 04:01 PM
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 01:29 AM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 10:46 PM
