![]() ![]() ![]() Join Date: Sep 2014
help: i will install Curt 56175 wire converter
2015 yaris hatchback
What and how should I remove the pieces of the trunk to install the curt 56175 wire converter, to avoid damaging any parts.. how i will connect this wire converert. |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
what is this wire converter for ?
i iwll use with this, becouse last time when i visited USA, one car "crash" my cargo carrier, and he said "i dont see it"
To wire up the taillight converter:
Brake: Light Blue (either side) Left Turn: Yellow (Left Tail Light) Right Turn: Sky Blue (Right Tail Light) Tail: Green (either side) Ground: White/Black (either side)
Thank you CTScott, i will need remove all plastics from rear trunk?
Either side, but you will need to run one wire over to the opposite side. You should not have to remove all of the plastics. You can open the hatches for access to the lights and then feed the wires down into the spare tire area. For exiting the car, the rubber plug at the bottom of the spare tire well is better than drilling a hole through metal.
![]() ![]() ![]() Drives: '09 Yaris 3dr, 13 F150rcsb 5.0 Join Date: Oct 2008
Did you get the trailer hitch to fit your 2015?
You are what you drive. |
Was "custom" made.. I upload picture An a moment
i live in México, and i cant go to USA before my trip..
a welder man, did my "custom" hitch.... |
Beautiful!
That does look good. It is quite low though, so you will have to be careful to not scrape your carrier.
#14 |
The carrier will be modify.. Maybe today i will go for it
#15 |
today i was installed the wire converter, but the right light do not work
see pict. any help it will be appreciated pict from left to right left side, right side (green/yellow wire) in both sides where the light bulb are installed right side "close up" (both pict) green wire from left to right... 4 pin connector to "floor" outside the car last pict.... box controller |
#16 |
Does just the right turn signal not work, or do none of the functions work on the right side?
#17 |
the tail light in the car work, but in the curt wire dont
#18 |
I figured that was the case, but through the curt, does everything except turn signal work on the right or does nothing work on the right?
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Help me install my Infinity Basslink! | wsladaritz | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 10-21-2008 01:15 PM |
| Help me install a converter to HU | wsladaritz | DIY / Maintenance / Service | 8 | 09-07-2007 07:54 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 02:05 PM |
