#361 |
やりすぎだ~
#362 |
![]() Drives: yaris sedan 08 Join Date: Jun 2014
duplicate reply sorry
#363 | |
#364 |
I accid had a duplicate reply, delayed posts. Sorry. BTW they fixed my car bolts both, even tho one was sheared off, they also fixed the seat adjust thing on drivers side that is a recall or enhancement w/o me even telling them too. I got a loaner car on them (brand new corolla) I was very impressed w/ their service had worse experiences at past dealers of other makes.
The seat works harder now but if its safer ok. Last edited by kaz777; 06-24-2014 at 09:24 PM. Reason: dup |
#365 |
Ruler of the free world
Drives: 09 Yaris 2D HB Join Date: Jul 2010
I stumbled across this thread and now I'm thinking I better do this! I got the letter about a year ago and forgot all about it.
![]() I think I'll try to get them out myself. I'm wondering why no one has thought to try and find better bolts.. something that has more resistance to corrosion.. like stainless steel maybe? What do you all think? Does stainless torque well? Will it hold the 118 ft/lbs? Any input is appreciated. |
#366 | |
#367 |
![]() Drives: 2007 Yaris Join Date: Sep 2011
Well the 07 sedan has been through many southern Ontario winters and I'm afraid to try and take the bolts out. My plan is to drill a drainage hole, and using the straw, spray oil on the threads of the bolt. It would have to be done periodically, but it might save the bolt from furthur corrosion. I see this as a better option than trying to remove it and breaking it for certain.
#368 |
![]() Drives: 2008 Yaris 2-Door (White) Join Date: Jan 2014
SS Too Brittle?
#369 |
The bolt is mounted in a metal tube that is then suspended in dense rubber so that the control arm can move, so there is definitely flex at that joint. The right blend of stainless would be fine, but off the shelf bolts would be more brittle of a stainless blend then would be appropriate.
#370 | |
#371 |
#372 | |
I guess stainless is out then? That's too bad. |
#373 |
As with most automotive problems, I usually mull it over for a few days before I tear into action.
There's no doubt that the (relatively) permanent solution is to get new bolts. Skip the seam sealer prescribed in the Toyota TSB because you will never get it 100% water tight anyway, and it will just delay evaporation of water that does get in there. Drill 1/4" holes so the water can drain out of that low spot. Paint the freshly cut metal to prevent corrosion. Slather the control arm hole/new bolt head washer with blue marine grade grease such as Bombardier Triple Guade grease. That stuff is so tacky, it's hard to wipe off with an alcohol soaked rag. It will surely fend off a few drops of water for the next 10 years. I am just outside of the 7 year warrnty cutoff. Hopefully some devine miracle will allow the old bolts to be removed in one piece. I really want to avoid dropping the subframe. |
#374 |
#375 |
![]() Drives: 2003 Toyota Echo Join Date: Sep 2012
Replaced the LCAs yesterday, successfully, without shearing any bolts or damaging threads. The alignment to get the arm is was the tricky part. Used a lube by a company called Schaeffer. Not available in stores and many times better than WD40. Before you laugh and say its from an infomercial, the guy who helped me with the arms had it in his shop. No heat needed at all to remove 12 yr old bolts without damage. Unreal stuff.
#376 |
![]() Drives: '08 yaris sedan Join Date: Apr 2013
It looks like i have some work to do...
Passenger side 20150620_170443.jpg Driver side 20150620_170618.jpg Any suggestions on the best way to remove the headless bolt? |
#377 |
I think you can lower the cradle a little & try to turn it out with a pipe wrench.
#378 |
I was thinking that was the most probable solution. Would it need to be on a lift, or could I use ramps?
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
