Old 11-28-2010, 05:18 AM   #73
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Lightbulb
Originally Posted by darkMINI View Post
Before you swapped the ECU was it just the Tach dial and pointer not illuminating, or both the Speedo and Tach dials/pointers?
after the swap, the gauge backlight, pointers(tach+speedo) is not working..Rest of the functions is working.
Below my observation:
My wiring harness is not the same. The canadian cluster has the illumination control and GCC/EU model don't have. To fix this, You have to swap/jumper or rig the illumination pinout of the new cluster.
I put it back my original cluster as I am annoyed without the illumination/backlight. Everything works fine. From here, I noticed also that they have different programming cluster daughter board. Tried to swap their daughter boards also but the results is more bad(none of the pointers is working).
ricepower is offline   Reply With Quote
Old 11-28-2010, 03:01 PM   #74
darkMINI
Drives: 08 hatch
So, I've been searching all these Tach Cluster threads and still have not been able to verify if I can put a tach cluster in my '08 3dr HB MT US base model. If it is possible does anyone have an idea of which clusters will work without issue?
I was thinking of trying a cluster from an '08 US HB auto trans model.
We need to make a chart showing what will work with what.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 11-28-2010, 05:15 PM   #75
For USDM ones, the key is getting one with ABS if your car has it and without if it doesn't. In some cases the opposite will still work, but you are always safe if you match for ABS.
Old 11-28-2010, 05:46 PM   #76
darkMINI
Drives: 08 hatch
Right on Scott, that narrows the search a bit.
Love your snowplow BTW
Old 07-18-2011, 04:59 PM   #77
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thread revival time!
I've been plowing though as many threads as I can, but I still can't find the part number for a USDM cluster w/tach and ABS. I've found some part numbers on villagetoyotaparts.com and toyoDIY, but the descriptions are either absent, or not helpful.
Here's what I've found so far at villagetoyotaparts.com for a 2010 USDM 3DR MT:
83800-52L30 - speedo only (2010 hatch, ebay listing)
83800-52L40 - ???
83800-52N61 - speedo only (2009 hatch, ebay listing)
83800-52N71 - w/tach and ABS
83800-52P01 - ???
83800-52X00 - ???
Could someone with a USDM hatch with tach pull their cluster and verify the part number?
*edit*
Ok, after more poking around at toyotapartszone.com, I found about a dozen part numbers for the 09 North American hatch. Sadly, they either say "Mexico spec" or "not available". The descriptions seem to be a bit better, but having a description for a part that doesn't exist anymore is pretty useless. =/
Old 07-18-2011, 05:54 PM   #78
83800-52L40 - ???
83800-52N71 - ???
83800-52P01 - ???
83800-52X00 - ???
*edit*
For an 09+ with ABS and the Tach: 83800-52N71
Old 12-21-2014, 11:55 PM   #79
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
I know this Thread is almost 4yrs old... Don't Shoot Me!
On the 09+ LB w/abs WITH TACH, does it matter?, or which Part # is correct for 5-Speed and which for AT?
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 12-22-2014, 04:03 AM   #80
yariseggvvti
Drives: Yaris Hatchieback
tach cluster
I got 07 hatch none tach and I found one for $150 09 hatch with tach. Can anyone provide me some information here please. Can i just swap it over and plug and play or I need to change wht hardness. Thx!!!
yariseggvvti is offline   Reply With Quote
Old 12-22-2014, 05:25 AM   #81
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
09 S Cluster needs to be matched with car with abs or the mph needle wont move.
S cluster doesnt matter Auto or Manual.
Harness is the same, its simple plug and play.
Check out my Build thread:
Old 12-30-2014, 01:46 AM   #82
yariseggvvti
Thanks for reply. So all 09 cluster comes with abs. Can i get one with out abs and then both will be working fine. thx!
Old 12-30-2014, 07:44 AM   #83
With US ones ALL come WITH ABS. The speedometer issue is only when using a JDM cluster on a non ABS US car. If you use a U.S. ABS one on a non ABS car the ABS and brake lights will always be on. You can disable those lights to make it usable.
Old 01-12-2015, 03:25 AM   #84
yariseggvvti
Thank you very much! CTScott
Old 03-06-2015, 08:31 PM   #85
MJZ
Drives: 2008 Yaris 3 Door Manual
I read this whole thread, is there an end all answer for this?
I'm reading "discon the battery first and it'll work" then "that doesn't work" then "the dealer can do it" then "the dealer can't do it"
What's the actual answer here??
I'd sure love to have a tach, on the cluster on my 08 manual...
MJZ is offline   Reply With Quote
Old 03-06-2015, 09:43 PM   #86
The final and definite answer is it can only be done by someone with specialized equipment to reflash the EEPROM on the module. It can't be done by disconnecting the battery and it can't be done by the dealer. I have the equipment and offer the service, if you track one down.
Old 03-06-2015, 10:03 PM   #87
MJZ
Good to know!
Old 04-02-2015, 08:26 PM   #88
scoobopdan
Drives: 2008 Yaris
CT, I'm thinking about doing the swap to the type S to get the tach. If I did this what would flashing the mileage include? I.e. do I need to send it to you with my old cluster or something and how much would you want?
scoobopdan is offline   Reply With Quote
Old 04-02-2015, 09:05 PM   #89
You would just have to send me the new one (and shoot me a pic of your current one with its current mileage). I charge $40 + return shipping to reprogram them.
Old 04-07-2015, 03:15 PM   #90
scoobopdan
Drives: 2008 Yaris
Good to know CT, I'm in the middle of moving so it may take a month or two but i'll definitely be PMing you in the future, thanks!
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 04:02 PM
Canada tach in a US Yaris LB tiksman DIY / Maintenance / Service 49 02-27-2007 02:40 AM
