Old 01-28-2015, 11:30 AM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
New Yaris
Hello everyone, I am a new owner of a 2010 2dr with a 5spd. I am liking the car so far. It's great for getting me to and from work.
The car has 68,000mi. Is there anything you would recommend changing/doing? Brake fluid, PS fluid, etc?
Also, I realized that my antenna is broken. Is there a good website that sells OEM Toyota parts, or even a decent aftermarket antenna?
Has anyone replaced their antenna before? How hard is it? I'm assuming you have to remove the headliner and unscrew it from under there.
attrapereves is offline   Reply With Quote
Old 01-28-2015, 11:43 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If you want an aftermarket antenna, try to find an antenna off of an S2000. Replacing an antenna difficulty: if you can replace a lightbulb, you can replace the antenna.
You literally unscrew it off. For that mileage I'd look at getting the tranny fluid changed, and the brakes flushed.
Old 01-28-2015, 12:39 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Pictures or your a spammer...
Sorry, we like pictures here... 2nd post requires a picture in order to get any form of help.
-Derrick-
Old 01-28-2015, 01:19 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
I would check the serpentine belt for cracks, and I would install/replace the cabin filter.
I would check on ebay for an OEM replacement antenna. I believe most of the Toyota antennas will fit, and some antennas from other makes will fit as well (Betrivent).
Old 01-28-2015, 07:06 PM   #5
attrapereves
Not sure if serious
It's not my favorite color, but it's not the worst. When I tint the windows, it will look much better.
Old 01-28-2015, 08:13 PM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Is the antenna broken off? If so it might be tricky to get it out. Would need pliers to unscrew it out.
Old 01-28-2015, 09:09 PM   #7
attrapereves
It looks like the threaded base has been torn out. No clue how someone would have managed that. The wire is sticking out and it's tied around a nut. The entire base will have to be replaced.
I bought the car at night, so didn't catch it. If I had, I would have made the dealer replace it before I bought the car.
Anywho... I'll be getting the tint done soon. I'm also going to throw some better wheels on there. I'll save those steel wheels for snow tires.
Old 01-28-2015, 09:15 PM   #8
Kar98
Drives: 2011 Scion tC
Lower it.
Kar98 is offline   Reply With Quote
Old 01-28-2015, 09:15 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
THat's going to require more than just getting a new antenna, you need the whole assembly. Got pictures of it?
Old 01-28-2015, 09:29 PM   #10
attrapereves
I can take a pic in the light tomorrow. Yep, I'll have to remove the headliner and unscrew the base from the roof of the car.
Any help with the part number for the base?
Old 01-28-2015, 09:38 PM   #11
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
For that I defer to other more resourceful members
Old 01-29-2015, 09:14 PM   #12
attrapereves
Here's what the antenna base looks like. I'm 99% sure it will need to be replaced.
Old 02-06-2015, 09:13 PM   #13
attrapereves
Another quick question.
My car was bought from a dealer. There was an oil change sticker in the window, leading me to believe that they changed the oil. However, when I changed the oil today, I noticed that there was a Microgard brand filter. This is not something a Toyota dealer would install, correct?
Old 02-06-2015, 09:55 PM   #14
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
It varies, I wouldn't say it's out of the realm of possibility that they would use an aftermarket filter to save money.
Old 02-07-2015, 10:54 AM   #15
attrapereves
Something else I realized. I do not see a power steering reservoir. This car has electronically assisted power steering, correct?
Old 02-07-2015, 04:41 PM   #16
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Correct. It is electric.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 04:13 AM
